hilfe.... LTEWATCH work with hawuei e-3372 key ?
Dieses Thema im Forum "LTE Speed & Speedtests" wurde erstellt von 1enry1, 4. November 2015.
  1. 1enry1
    1enry1 New Member
    2. November 2015
    work or not, if yes in how mode ???
  2. KOSH
    KOSH Member
    27. April 2014
    Niederösterreich
    LTE Watch work only with E3372s HILINK now not with 3372h ...
  3. 1enry1
    1enry1 New Member
    2. November 2015
    hi, i have the H version...none work in some mode for mine ? vielen danke
  4. 1enry1
    1enry1 New Member
    2. November 2015
    sorry but the H version is HILINK !
  5. KOSH
    KOSH Member
    27. April 2014
    Niederösterreich
    Yes but the H Version is an other Model its newer intern smaller and has other Firmware.
    Also the at^Setport is different but I think in future it could be possible to integrate E3372h in LTE-Watch
    You can also flash HILINK on E3372s(tick only) Version ! (without token so its much easy)
    E3372h here it looks like you need a token like E5186 or E5786 to see Parameter
    I see this Information in Fin page
    Tällaisella hätäratkaisulla sain signaalitiedot pävitittymään aina.
    @Echo off
    :silmukka
    wget -q http://192.168.8.1/html/home.html -O nul --save-cookies cookie --keep-session-cookies
    wget -q http://192.168.8.1/api/device/signal -O signal --load-cookies cookie
    cls
    type signal
    REM viive
    ping 342234 -n 2 > NUL
    goto silmukka
    Evästeen tiedot taitaa saada myös osoitteella: http://192.168.8.1/api/webserver/SesTokInfo
