    Seit Wochen immer stündliche Abbrüche
    DARK-THREAT
    EasyBox
    Ich habe seit nun mehreren Wochen das Problem, das meine Verbindung mit dem Internet immer zur Stunde xx:06 abbricht.
    Im Logbuch steht auch immer wieder sowas zur jeden Stunde:
    09/03/2015 18:08:13 DHCP client bound lease time:2h:0m:0s (voice_APN) WAN
    09/03/2015 18:08:13 DHCP client bound Domain: (voice_APN) WAN
    09/03/2015 18:08:12 DHCP client bound Second DNS: ..... (voice_APN) WAN
    09/03/2015 18:08:12 DHCP client bound Primary DNS: .....(voice_APN) WAN
    09/03/2015 18:08:12 DHCP client bound IP:.... Subnet:255.255.255.252 (voice_APN) WAN
    09/03/2015 18:07:57 DHCP client bound lease time:2h:0m:0s (data_APN) WAN
    09/03/2015 18:07:57 DHCP client bound Domain: (data_APN) WAN
    09/03/2015 18:07:56 DHCP client bound Gateway: ... .(data_APN) WAN
    09/03/2015 18:07:55 DHCP client bound Second DNS: .......(data_APN) WAN
    09/03/2015 18:07:55 DHCP client bound Primary DNS: .... (data_APN) WAN
    09/03/2015 18:07:55 DHCP client bound IP: ...... Subnet:255.255.255.252 (data_APN) WAN
    09/03/2015 18:07:33 Netdev:LTE voice-APN up WAN
    09/03/2015 18:07:21 Netdev:LTE data-APN up WAN
    09/03/2015 18:07:17 LTE attach to network, 4G ECGI:0x7e6401, PCI:439, RSRP:-109, SINR:3.4 WAN
    09/03/2015 18:07:16 LTE serving cell changed. 4G ECGI:0x7e6401, PCI:439, RSRP:-109, SINR:3.4 WAN
    09/03/2015 18:07:00 Netdev:LTE voice-APN down WAN
    09/03/2015 18:06:56 Netdev:LTE data-APN down WAN
    09/03/2015 18:06:52 LTE detach from network WAN
    IPs habe ich gelöscht.
    Nur Fehler:
    09/03/2015 21:06:49 LTE detach from network WAN
    09/03/2015 12:07:00 LTE detach from network WAN
    09/03/2015 11:06:57 LTE detach from network WAN
    09/03/2015 02:06:47 [VoIP] SIP Account 1 Regist Timeout Sprache
    09/03/2015 02:06:10 [VoIP] SIP Account 1 Regist Timeout Sprache
    08/03/2015 12:07:14 LTE detach from network WAN
    08/03/2015 11:06:42 [VoIP] SIP Account 1 Regist Timeout Sprache
    08/03/2015 11:06:06 [VoIP] SIP Account 1 Regist Timeout Sprache
    08/03/2015 06:07:31 LTE detach from network WAN
    08/03/2015 01:07:28 LTE detach from network WAN
    07/03/2015 21:06:54 LTE detach from network WAN
    07/03/2015 18:07:10 LTE detach from network WAN
    07/03/2015 16:06:56 LTE detach from network WAN
    07/03/2015 07:06:40 [VoIP] SIP Account 1 Regist Timeout Sprache
    07/03/2015 02:07:24 LTE detach from network WAN
    07/03/2015 01:07:12 LTE detach from network WAN
    06/03/2015 23:07:18 LTE detach from network WAN
    06/03/2015 11:07:00 LTE detach from network WAN
    Problem besteht seit 26.2. an der LTE Station ECGI:0x7e6401 (OXLN56)
    Da bin ich schon seit 6.3. dran und habe ein Ticket erstellt.
    Mit Besserung kann man rechnen, wenn das Problem behoben ist, bzw. das Ticket beantwortet ist.
    Kann/wird aber ein paar Tage dauern.
    Hatte ich doch geschrieben:
    Oder meinst du wo die steht?
    Alte B183
    06369 Radegast
    Geo: 51.663 12.091583
    DARK-THREAT
    EasyBox
    Alte B183
    06369 Radegast
    Ja genau, wo die steht.
    Finde es richtig erstaunlich, dass erst dort der Mast ist. Dachte immer es sind andere, die deutlich näher wären und mein Router ward immer dort ausgerichtet.
    Das ich 1-3 Balken habe, ist ja ein Wunder.
    DARK-THREAT
    EasyBox
    Immer noch die gleichen Probleme. Mittlerweile sehr oft Zellenwechsel zwischen 3 verschiedene Zellen.
    Hallo DARK-THREAT.
    Kleine Korrektur von mir:
    Das Problem ist wieder da. Nach meinem Ticket vom März war das Problem bis zum 31.3. behoben.
    Leider ist es dann wieder aufgetreten.
    Dazu habe schon am 8.4. ein neues Ticket erstellt.
    Diese werde ich jetzt an mahnen, weil es immer noch in Zugewiesen ist.
    Seit 15.4.wieder ok.
    Oder?
    Hoffentlich diesmal für länger.
