{"name":"LTE Hardware","description":"Ger\u00e4te f\u00fcr LTE im \u00dcberblick","url":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all","home":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all","gmt_offset":"0","timezone_string":"","page_for_posts":0,"page_on_front":0,"show_on_front":"posts","namespaces":["oembed\/1.0","iawp","jetpack\/v4","rankmath\/v1","rankmath\/v1\/setupWizard","shariff\/v1","postviews\/v1","yet-another-stars-rating\/v1","jetpack\/v4\/stats-app","jetpack\/v4\/blaze-app","jetpack\/v4\/blaze","rankmath\/v1\/ai-visibility","rankmath\/v1\/ca","rankmath\/v1\/an","rankmath\/v1\/in","rankmath\/v1\/status","jetpack\/v4\/import","wpcom\/v2","jetpack-boost\/v1","my-jetpack\/v1","jetpack\/v4\/explat","wpcom\/v3","mcp","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"description":"Das zu verwendende oEmbed-Format.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Die maximale Breite des eingebundenen Frames in Pixel.","type":"integer","default":600,"required":false},"maxheight":{"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixel.","type":"integer","required":false},"discover":{"description":"Ob eine oEmbed-Discovery-Anfrage f\u00fcr nicht autorisierte Anbieter durchgef\u00fchrt werden soll.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/oembed\/1.0\/proxy"}]}},"\/iawp":{"namespace":"iawp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"iawp","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/iawp"}]}},"\/iawp\/search":{"namespace":"iawp","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/iawp\/search"}]}},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/backup-helper-script":{"namespace":"jetpack\/v4","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"helper":{"description":"Backup-Hilfsskripttext mit Base64-Kodierung.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"path":{"description":"Pfad zum Backup-Hilfsskript","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/backup-helper-script"}]}},"\/jetpack\/v4\/database-object\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"object_type":{"description":"Objekttyp, der von der Datenbank abgerufen werden soll","required":true},"object_id":{"description":"ID des Datenbank-Objektes, das abgerufen werden soll","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/database-object\/backup"}]}},"\/jetpack\/v4\/options\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eine oder mehrere Bezeichnungen der Option sollen im Backup inbegriffen sein","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/options\/backup"}]}},"\/jetpack\/v4\/comments\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/posts\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/terms\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/users\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/site\/backup\/undo-event":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/undo-event"}]}},"\/jetpack\/v4\/orders\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/site\/backup\/preflight":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/preflight"}]}},"\/jetpack\/v4\/site\/cache\/flush":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/cache\/flush"}]}},"\/jetpack\/v4\/jetpack-ai-jwt":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/jetpack-ai-jwt"}]}},"\/jetpack\/v4\/plans":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/plans"}]}},"\/jetpack\/v4\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/products"}]}},"\/jetpack\/v4\/marketing\/survey":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/marketing\/survey"}]}},"\/jetpack\/v4\/rewind":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/rewind"}]}},"\/jetpack\/v4\/scan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/scan"}]}},"\/jetpack\/v4\/connection\/url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"from":{"type":"string","required":false},"redirect":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/url"}]}},"\/jetpack\/v4\/tracking\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"tracks_opt_out":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/tracking\/settings"}]}},"\/jetpack\/v4\/site\/features":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/features"}]}},"\/jetpack\/v4\/site\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/products"}]}},"\/jetpack\/v4\/site\/purchases":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/purchases"}]}},"\/jetpack\/v4\/site\/benefits":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/benefits"}]}},"\/jetpack\/v4\/site\/activity":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/activity"}]}},"\/jetpack\/v4\/module\/all":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/module\/all"}]}},"\/jetpack\/v4\/module\/all\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"default":"","type":"array","items":{"type":"string"},"required":true},"active":{"default":true,"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/module\/all\/active"}]}},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Jetpack-Bl\u00f6cke deaktiviert.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Farbschema.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Foto-Metadaten (<a href=\"https:\/\/en.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) im Karussell zeigen, wenn verf\u00fcgbar.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Den Kommentarbereich im Karussell anzeigen","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Begr\u00fc\u00dfungstext","type":"string","default":"Kommentar verfassen","required":false},"jetpack_comment_form_color_scheme":{"description":"Farbschema","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"enable_blocks_comments":{"description":"Bl\u00f6cke in Kommentaren aktivieren","type":"boolean","default":1,"required":false},"jetpack_portfolio":{"description":"Jetpack Portfolio-Inhaltstyp aktivieren\/deaktivieren.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"H\u00f6chstzahl der anzuzeigenden Eintr\u00e4ge in Portfolio-Seiten.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Jetpack Referenz-Inhaltstyp aktivieren\/deaktivieren.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"H\u00f6chstzahl der anzuzeigenden Eintr\u00e4ge in Referenz-Seiten.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Automatische Regeln aktivieren\u00a0\u2013 Sch\u00fctze deine Website mit automatischen Sicherheitsregeln vor nicht vertrauensw\u00fcrdigen Traffic-Quellen.","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Negativliste: Blockiere eine bestimmte Anfrage-IP.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Blockierte IP-Adressen","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Positivliste: Lasse eine bestimmte Anfrage-IP zu.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"IP-Adressen auf der Liste \u201eImmer zulassen\u201c ","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Teile grundlegende Daten mit Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Teile detaillierte Daten mit Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Alle Galerie-Bilder in einem coolen Mosaik anzeigen.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Sieh dir die Profile der Menschen an, wenn du mit der Maus \u00fcber ihre Gravatare f\u00e4hrst","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Bis zur Unendlichkeit und weiter","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Google Analytics mit \u201eEndloses Scrollen\u201c verwenden","type":"boolean","default":0,"required":false},"wpl_default":{"description":"WordPress.com-Likes sind","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Sende eine E-Mail-Benachrichtigung, wenn jemandem ein Beitrag gef\u00e4llt.","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Verwende Markdown f\u00fcr Kommentare.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Verwende Markdown f\u00fcr Beitr\u00e4ge.","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Erhalte E-Mail-Benachrichtigungen von Monitor.","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"E-Mail-Adresse","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Protect API-Schl\u00fcssel","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Globale IP-Zulassungsliste sch\u00fctzen","type":"string","default":"","required":false},"sharing_services":{"description":"Aktivierte Dienste und durch einen Button verdeckte Dienste.","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Button-Stil","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"Teilen-Beschriftung","type":"string","default":"","required":false},"show":{"description":"Aufrufe, wo die Buttons angezeigt werden","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"Der Twitter-Benutzername des Besitzers der Domain dieser Website.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Jetpack-eigenes CSS und JavaScript deaktivieren","type":"boolean","default":0,"required":false},"custom":{"description":"Individuelle Dienste zum Teilen, vom Nutzer hinzugef\u00fcgt","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Individuellen Dienst zum Teilen entfernen","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"Zwei-Schritt-Authentifizierung erfordern","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Mit E-Mail-Adresse abgleichen","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Eine &lt;em&gt;&#8222;Blog folgen&#8220;&lt;\/em&gt;-Option im Kommentar-Formular anzeigen","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Eine &lt;em&gt;&#8222;Kommentaren folgen&#8220;&lt;\/em&gt;-Option im Kommentarformular anzeigen","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Array von Beitragskategorie-IDs, die als Newsletter-Kategorien markiert sind","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Ob die Newsletter-Kategorien aktiviert sind oder nicht","type":"boolean","default":0,"required":false},"wpcom_newsletter_send_default":{"description":"Ob beim Ver\u00f6ffentlichen eines Beitrags standardm\u00e4\u00dfig Newsletter-E-Mails gesendet werden sollen","type":"boolean","default":1,"required":false},"wpcom_featured_image_in_email":{"description":"Ob das Beitragsbild zur E-Mail hinzugef\u00fcgt werden soll oder nicht","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Ob der Avatar des Autors in der Verfasserzeile der E-Mail angezeigt werden soll","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Ob der Anzeigename des Autors in der Verfasserzeile der E-Mail angezeigt werden soll","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Ob das Datum in der Verfasserzeile der E-Mail angezeigt werden soll","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Ob der Textauszug in der E-Mail verwendet werden soll oder nicht","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Verhalten f\u00fcr Antwort-E-Mail bei Newsletter-E-Mails","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Von-Name f\u00fcr Newsletter-E-Mails","type":"string","default":"","required":false},"sm_enabled":{"description":"Zeige Lesern ein Pop-up-Abonnement-Modal.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Abonnement-Overlay auf der Startseite anzeigen.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Zeige einen schwebenden Abonnieren-Button.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"F\u00fcge am Ende jedes Beitrags den Abonnieren-Block hinzu.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"F\u00fcge den Block zur Anmeldung f\u00fcr Abonnenten zur Navigation hinzu.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"F\u00fcge den Abonnieren-Block zur Navigation hinzu.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"E-Mail-Benachrichtigung senden, wenn jemand meinen Blog abonniert","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Optionen, die in E-Mail-Templates f\u00fcr Abonnements und im Abonnieren-Block verwendet werden: \u201einvitation\u201c, \u201ewelcome\u201c, \u201ecomment_follow\u201c, \u201esubscribe_modal_heading\u201c, \u201efree_tier_description\u201c und \u201ehide_free_tier\u201c.","type":"object","default":{"invitation":"","welcome":"","comment_follow":"","subscribe_modal_heading":"","free_tier_description":"","hide_free_tier":false},"required":false},"show_headline":{"description":"\u00c4hnliche Inhalte mit einer \u00dcberschrift hervorheben","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Ein Vorschaubild anzeigen, sofern verf\u00fcgbar","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Sofortsuche aktivieren","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Verf\u00fcgt \u00fcber einen aktiven Jetpack Search-Produktkauf","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"L\u00f6se eine automatische Konfiguration der Sofortsuche aus","type":"boolean","default":0,"required":false},"google":{"description":"Google Search Console","type":"string","default":"","required":false},"bing":{"description":"Bing Webmaster Center","type":"string","default":"","required":false},"pinterest":{"description":"Pinterest-Website-Best\u00e4tigung","type":"string","default":"","required":false},"yandex":{"description":"Yandex-Website-Verifizierung","type":"string","default":"","required":false},"facebook":{"description":"Facebook Domainbest\u00e4tigung","type":"string","default":"","required":false},"enable_header_ad":{"description":"Zeige auf jeder Seite oben eine Werbeeinheit an.","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"Ist die Website f\u00fcr WordAds genehmigt?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"Zweite Werbeanzeige unter Beitrag anzeigen?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"Inline-Werbung in Beitragsinhalt anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"Werbeanzeigen auf der Startseite anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"Werbeanzeigen auf Beitr\u00e4gen anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"Werbeanzeigen auf Seiten anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"Werbeanzeigen auf Archivseiten anzeigen?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":"Individuelle Datei ads.txt","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Individuelle ads.txt-Eintr\u00e4ge","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Unterst\u00fctzung f\u00fcr CCPA (California Consumer Privacy Act) aktivieren","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL der Datenschutzerkl\u00e4rung","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Banner zur Verwaltung der DSGVO-Einwilligung f\u00fcr WordAds aktivieren","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"F\u00fcge ein kleines Diagramm in deine Adminleiste mit einer Momentaufnahme deines Traffics innerhalb von 48\u00a0Stunden ein.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Vorschau der neuen Jetpack-Statistiken-Erfahrung (Experimentell).","type":"boolean","default":1,"required":false},"roles":{"description":"W\u00e4hle die Benutzerrollen aus, die auf die Statistik zugreifen d\u00fcrfen.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Z\u00e4hle die Seitenaufrufe von registrierten Benutzern, die angemeldet sind.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"Blog-ID","type":"boolean","default":0,"required":false},"do_not_track":{"description":"Kein Tracking","type":"boolean","default":1,"required":false},"version":{"description":"Version.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Upgrade-Anstupser ausblenden","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Zeige Beitragsaufrufe im WordPress.com-Reader.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Hauptsprache dieser Website","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Meta-Beschreibung der Startseite.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"SEO-Seitentitelstrukturen.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"jetpack_seo_llms_txt_enabled":{"description":"Generiere eine llms.txt-Datei, um AI Assistants bei deinen Inhalten zu unterst\u00fctzen.","type":"boolean","default":0,"required":false},"jetpack_seo_ai_crawler_overrides":{"description":"KI-Crawler \u00dcberschreibungen erlauben\/blockieren.","type":"object","default":[],"required":false},"videopress_private_enabled_for_site":{"description":"Video-Privatsph\u00e4re: Einschr\u00e4nken der Anzeige auf Mitglieder dieser Website","type":"boolean","default":0,"required":false},"videopress_share_menu_disabled":{"description":"Blende das Teilen-Men\u00fc bei jedem Video aus und \u00fcberschreibe dabei die eigenen Einstellungen jedes Videos","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Generiere SEO-Titel, SEO-Beschreibung und Bild-Alt-Text f\u00fcr neue Beitr\u00e4ge automatisch.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"activity-log":{"description":"","type":"boolean","default":0,"required":false},"ai":{"description":"","type":"boolean","default":0,"required":false},"backup":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"podcast":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sitemaps":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"active":{"default":true,"type":"boolean","required":true}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"range":{"default":"day","type":"string","required":false}}}]},"\/jetpack\/v4\/module\/(?P<service>[a-z\\-]+)\/key\/check":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"api_key":{"default":"","type":"string","required":false}}}]},"\/jetpack\/v4\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Jetpack-Bl\u00f6cke deaktiviert.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Farbschema.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Foto-Metadaten (<a href=\"https:\/\/en.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) im Karussell zeigen, wenn verf\u00fcgbar.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Den Kommentarbereich im Karussell anzeigen","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Begr\u00fc\u00dfungstext","type":"string","default":"Kommentar verfassen","required":false},"jetpack_comment_form_color_scheme":{"description":"Farbschema","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"enable_blocks_comments":{"description":"Bl\u00f6cke in Kommentaren aktivieren","type":"boolean","default":1,"required":false},"jetpack_portfolio":{"description":"Jetpack Portfolio-Inhaltstyp aktivieren\/deaktivieren.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"H\u00f6chstzahl der anzuzeigenden Eintr\u00e4ge in Portfolio-Seiten.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Jetpack Referenz-Inhaltstyp aktivieren\/deaktivieren.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"H\u00f6chstzahl der anzuzeigenden Eintr\u00e4ge in Referenz-Seiten.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Automatische Regeln aktivieren\u00a0\u2013 Sch\u00fctze deine Website mit automatischen Sicherheitsregeln vor nicht vertrauensw\u00fcrdigen Traffic-Quellen.","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Negativliste: Blockiere eine bestimmte Anfrage-IP.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Blockierte IP-Adressen","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Positivliste: Lasse eine bestimmte Anfrage-IP zu.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"IP-Adressen auf der Liste \u201eImmer zulassen\u201c ","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Teile grundlegende Daten mit Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Teile detaillierte Daten mit Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Alle Galerie-Bilder in einem coolen Mosaik anzeigen.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Sieh dir die Profile der Menschen an, wenn du mit der Maus \u00fcber ihre Gravatare f\u00e4hrst","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Bis zur Unendlichkeit und weiter","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Google Analytics mit \u201eEndloses Scrollen\u201c verwenden","type":"boolean","default":0,"required":false},"wpl_default":{"description":"WordPress.com-Likes sind","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Sende eine E-Mail-Benachrichtigung, wenn jemandem ein Beitrag gef\u00e4llt.","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Verwende Markdown f\u00fcr Kommentare.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Verwende Markdown f\u00fcr Beitr\u00e4ge.","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Erhalte E-Mail-Benachrichtigungen von Monitor.","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"E-Mail-Adresse","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Protect API-Schl\u00fcssel","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Globale IP-Zulassungsliste sch\u00fctzen","type":"string","default":"","required":false},"sharing_services":{"description":"Aktivierte Dienste und durch einen Button verdeckte Dienste.","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Button-Stil","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"Teilen-Beschriftung","type":"string","default":"","required":false},"show":{"description":"Aufrufe, wo die Buttons angezeigt werden","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"Der Twitter-Benutzername des Besitzers der Domain dieser Website.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Jetpack-eigenes CSS und JavaScript deaktivieren","type":"boolean","default":0,"required":false},"custom":{"description":"Individuelle Dienste zum Teilen, vom Nutzer hinzugef\u00fcgt","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Individuellen Dienst zum Teilen entfernen","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"Zwei-Schritt-Authentifizierung erfordern","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Mit E-Mail-Adresse abgleichen","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Eine &lt;em&gt;&#8222;Blog folgen&#8220;&lt;\/em&gt;-Option im Kommentar-Formular anzeigen","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Eine &lt;em&gt;&#8222;Kommentaren folgen&#8220;&lt;\/em&gt;-Option im Kommentarformular anzeigen","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Array von Beitragskategorie-IDs, die als Newsletter-Kategorien markiert sind","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Ob die Newsletter-Kategorien aktiviert sind oder nicht","type":"boolean","default":0,"required":false},"wpcom_newsletter_send_default":{"description":"Ob beim Ver\u00f6ffentlichen eines Beitrags standardm\u00e4\u00dfig Newsletter-E-Mails gesendet werden sollen","type":"boolean","default":1,"required":false},"wpcom_featured_image_in_email":{"description":"Ob das Beitragsbild zur E-Mail hinzugef\u00fcgt werden soll oder nicht","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Ob der Avatar des Autors in der Verfasserzeile der E-Mail angezeigt werden soll","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Ob der Anzeigename des Autors in der Verfasserzeile der E-Mail angezeigt werden soll","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Ob das Datum in der Verfasserzeile der E-Mail angezeigt werden soll","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Ob der Textauszug in der E-Mail verwendet werden soll oder nicht","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Verhalten f\u00fcr Antwort-E-Mail bei Newsletter-E-Mails","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Von-Name f\u00fcr Newsletter-E-Mails","type":"string","default":"","required":false},"sm_enabled":{"description":"Zeige Lesern ein Pop-up-Abonnement-Modal.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Abonnement-Overlay auf der Startseite anzeigen.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Zeige einen schwebenden Abonnieren-Button.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"F\u00fcge am Ende jedes Beitrags den Abonnieren-Block hinzu.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"F\u00fcge den Block zur Anmeldung f\u00fcr Abonnenten zur Navigation hinzu.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"F\u00fcge den Abonnieren-Block zur Navigation hinzu.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"E-Mail-Benachrichtigung senden, wenn jemand meinen Blog abonniert","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Optionen, die in E-Mail-Templates f\u00fcr Abonnements und im Abonnieren-Block verwendet werden: \u201einvitation\u201c, \u201ewelcome\u201c, \u201ecomment_follow\u201c, \u201esubscribe_modal_heading\u201c, \u201efree_tier_description\u201c und \u201ehide_free_tier\u201c.","type":"object","default":{"invitation":"","welcome":"","comment_follow":"","subscribe_modal_heading":"","free_tier_description":"","hide_free_tier":false},"required":false},"show_headline":{"description":"\u00c4hnliche Inhalte mit einer \u00dcberschrift hervorheben","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Ein Vorschaubild anzeigen, sofern verf\u00fcgbar","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Sofortsuche aktivieren","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Verf\u00fcgt \u00fcber einen aktiven Jetpack Search-Produktkauf","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"L\u00f6se eine automatische Konfiguration der Sofortsuche aus","type":"boolean","default":0,"required":false},"google":{"description":"Google Search Console","type":"string","default":"","required":false},"bing":{"description":"Bing Webmaster Center","type":"string","default":"","required":false},"pinterest":{"description":"Pinterest-Website-Best\u00e4tigung","type":"string","default":"","required":false},"yandex":{"description":"Yandex-Website-Verifizierung","type":"string","default":"","required":false},"facebook":{"description":"Facebook Domainbest\u00e4tigung","type":"string","default":"","required":false},"enable_header_ad":{"description":"Zeige auf jeder Seite oben eine Werbeeinheit an.","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"Ist die Website f\u00fcr WordAds genehmigt?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"Zweite Werbeanzeige unter Beitrag anzeigen?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"Inline-Werbung in Beitragsinhalt anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"Werbeanzeigen auf der Startseite anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"Werbeanzeigen auf Beitr\u00e4gen anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"Werbeanzeigen auf Seiten anzeigen?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"Werbeanzeigen auf Archivseiten anzeigen?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":"Individuelle Datei ads.txt","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Individuelle ads.txt-Eintr\u00e4ge","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Unterst\u00fctzung f\u00fcr CCPA (California Consumer Privacy Act) aktivieren","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL der Datenschutzerkl\u00e4rung","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Banner zur Verwaltung der DSGVO-Einwilligung f\u00fcr WordAds aktivieren","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"F\u00fcge ein kleines Diagramm in deine Adminleiste mit einer Momentaufnahme deines Traffics innerhalb von 48\u00a0Stunden ein.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Vorschau der neuen Jetpack-Statistiken-Erfahrung (Experimentell).","type":"boolean","default":1,"required":false},"roles":{"description":"W\u00e4hle die Benutzerrollen aus, die auf die Statistik zugreifen d\u00fcrfen.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Z\u00e4hle die Seitenaufrufe von registrierten Benutzern, die angemeldet sind.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"Blog-ID","type":"boolean","default":0,"required":false},"do_not_track":{"description":"Kein Tracking","type":"boolean","default":1,"required":false},"version":{"description":"Version.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Upgrade-Anstupser ausblenden","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Zeige Beitragsaufrufe im WordPress.com-Reader.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Hauptsprache dieser Website","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Meta-Beschreibung der Startseite.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"SEO-Seitentitelstrukturen.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"jetpack_seo_llms_txt_enabled":{"description":"Generiere eine llms.txt-Datei, um AI Assistants bei deinen Inhalten zu unterst\u00fctzen.","type":"boolean","default":0,"required":false},"jetpack_seo_ai_crawler_overrides":{"description":"KI-Crawler \u00dcberschreibungen erlauben\/blockieren.","type":"object","default":[],"required":false},"videopress_private_enabled_for_site":{"description":"Video-Privatsph\u00e4re: Einschr\u00e4nken der Anzeige auf Mitglieder dieser Website","type":"boolean","default":0,"required":false},"videopress_share_menu_disabled":{"description":"Blende das Teilen-Men\u00fc bei jedem Video aus und \u00fcberschreibe dabei die eigenen Einstellungen jedes Videos","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Generiere SEO-Titel, SEO-Beschreibung und Bild-Alt-Text f\u00fcr neue Beitr\u00e4ge automatisch.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"activity-log":{"description":"","type":"boolean","default":0,"required":false},"ai":{"description":"","type":"boolean","default":0,"required":false},"backup":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"podcast":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sitemaps":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false}}},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/settings"}]}},"\/jetpack\/v4\/settings\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false}}}]},"\/jetpack\/v4\/options\/(?P<options>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/updates\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/updates\/plugins"}]}},"\/jetpack\/v4\/notice\/(?P<notice>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/plugins":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org-Plugin-Verzeichnis-Titelform.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Status der Plugin-Aktivierung.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"source":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/plugins"}]}},"\/jetpack\/v4\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"type":"string","required":true},"source":{"type":"string","required":false}}}]},"\/jetpack\/v4\/plugin\/(?P<plugin>[a-z\\\/\\.\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/widgets\/(?P<id>[0-9a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"keyring_id":{"type":"integer","required":true}}}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)\/(?<keyring_id>[0-9]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/jetpack_crm":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"extension":{"type":"text","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/jetpack_crm"}]}},"\/jetpack\/v4\/purchase-token":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/purchase-token"}]}},"\/jetpack\/v4\/seen-wc-connection-modal":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/seen-wc-connection-modal"}]}},"\/jetpack\/v4\/subscribers\/auth":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"Die URL, an die weitergeleitet werden soll.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/subscribers\/auth"}]}},"\/jetpack\/v4\/features\/available":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/features\/available"}]}},"\/jetpack\/v4\/features\/enabled":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/features\/enabled"}]}},"\/jetpack\/v4\/licensing\/error":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"error":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/licensing\/error"}]}},"\/jetpack\/v4\/licensing\/set-license":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"license":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/licensing\/set-license"}]}},"\/jetpack\/v4\/licensing\/user\/licenses":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/licensing\/user\/licenses"}]}},"\/jetpack\/v4\/licensing\/user\/counts":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/licensing\/user\/counts"}]}},"\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"last_detached_count":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss"}]}},"\/jetpack\/v4\/licensing\/attach-licenses":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"licenses":{"type":"array","items":{"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/licensing\/attach-licenses"}]}},"\/rankmath\/v1":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1"}]}},"\/rankmath\/v1\/saveModule":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"module":{"type":"string","description":"Modul-Slug","required":true},"state":{"type":"string","description":"Modulstatus ist entweder ein oder aus","enum":["on","off"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/saveModule"}]}},"\/rankmath\/v1\/toolsAction":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"action":{"type":"string","description":"Durchzuf\u00fchrende Aktion","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/toolsAction"}]}},"\/rankmath\/v1\/updateMode":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"mode":{"type":"string","description":"Einzustellender Modus","enum":["easy","advanced","custom"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateMode"}]}},"\/rankmath\/v1\/dashboardWidget":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/dashboardWidget"}]}},"\/rankmath\/v1\/updateSeoScore":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postScores":{"type":"object","description":"Ergebnisse ver\u00f6ffentlichen","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateSeoScore"}]}},"\/rankmath\/v1\/updateSettings":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateSettings"}]}},"\/rankmath\/v1\/searchPage":{"namespace":"rankmath\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/searchPage"}]}},"\/rankmath\/v1\/disconnectSite":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"token":{"type":"string","description":"Website-Token","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/disconnectSite"}]}},"\/rankmath\/v1\/getFeaturedImageId":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postId":{"type":"integer","description":"Beitrags-ID","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/getFeaturedImageId"}]}},"\/rankmath\/v1\/updateRedirection":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"Eindeutige Objekt-ID","required":true},"objectType":{"type":"string","default":"post","description":"Objekttyp d.h. Stelle, Begriff, Benutzer","required":true},"hasRedirect":{"type":"boolean","description":"Ob das Objekt eine Weiterleitung hat oder nicht","required":true},"redirectionID":{"type":"string","description":"Umleitungs-ID","required":false},"redirectionUrl":{"type":"string","description":"Umleitungs-URL","required":false},"redirectionType":{"type":"string","default":"301","description":"Umleitungstyp","enum":["301","302","307","410","451"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateRedirection"}]}},"\/rankmath\/v1\/updateMeta":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Objekttyp d.h. Stelle, Begriff, Benutzer","required":true},"objectID":{"type":"integer","description":"Eindeutige Objekt-ID","required":true},"meta":{"description":"Meta zum Hinzuf\u00fcgen oder Aktualisieren von Daten.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateMeta"}]}},"\/rankmath\/v1\/updateSchemas":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Objekttyp d.h. Stelle, Begriff, Benutzer","required":true},"objectID":{"type":"integer","description":"Eindeutige Objekt-ID","required":true},"schemas":{"description":"Schemas f\u00fcr neue oder aktualisierte Daten.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateSchemas"}]}},"\/rankmath\/v1\/updateMetaBulk":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"rows":{"description":"Ausgew\u00e4hlte Beitr\u00e4ge, f\u00fcr die die Daten aktualisiert werden sollen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/updateMetaBulk"}]}},"\/rankmath\/v1\/setupWizard":{"namespace":"rankmath\/v1\/setupWizard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/setupWizard","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/setupWizard"}]}},"\/rankmath\/v1\/setupWizard\/getStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Aktueller Schritt","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/setupWizard\/getStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Aktueller Schritt","required":true},"value":{"type":"object","description":"Aktuelle Schrittdaten","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/setupWizard\/updateStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateTrackingOptin":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"enable_tracking":{"type":"string","description":"Tracking aktivieren","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/setupWizard\/updateTrackingOptin"}]}},"\/shariff\/v1":{"namespace":"shariff\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"shariff\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/shariff\/v1"}]}},"\/shariff\/v1\/share_counts":{"namespace":"shariff\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL des Beitrags oder der Seite, f\u00fcr die Share-Counts abgefragt werden sollen.","required":true},"services":{"description":"Eine Liste mit Dienste durch | getrennt. Beispiel: mastodon|facebook|xing","required":true},"timestamp":{"description":"Der Zeitstempel der letzten Beitragsaktualisierung. Dieser wird f\u00fcr die dynamische Cache-Lebensdauer verwendet.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/shariff\/v1\/share_counts"}]}},"\/postviews\/v1":{"namespace":"postviews\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"postviews\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/postviews\/v1"}]}},"\/postviews\/v1\/post\/(?P<id>\\d+)\/view":{"namespace":"postviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"nonce":{"description":"The wp_postviews_nonce the counting script is given.","required":true}}}]},"\/yet-another-stars-rating\/v1":{"namespace":"yet-another-stars-rating\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yet-another-stars-rating\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/yet-another-stars-rating\/v1"}]}},"\/yet-another-stars-rating\/v1\/yasr-multiset":{"namespace":"yet-another-stars-rating\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"set_id":{"required":true},"post_id":{"required":false},"visitor":{"default":0,"required":false},"comment_id":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/yet-another-stars-rating\/v1\/yasr-multiset"}]}},"\/yet-another-stars-rating\/v1\/yasr-rankings":{"namespace":"yet-another-stars-rating\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"source":{"required":true},"show":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/yet-another-stars-rating\/v1\/yasr-rankings"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Vor die Statistik-IDs zu setzendes Pr\u00e4fix.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/sync\/full-sync":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"description":"Datenmodule, die in der vollen Synchronisierung inbegriffen sein sollten","type":"array","required":false},"users":{"description":"Benutzer-IDs sollen in der vollen oder \u201eurspr\u00fcnglichen\u201c Synchronisierung inbegriffen sein","required":false},"posts":{"description":"Beitrags-IDs sollen in der vollen Synchronisierung inbegriffen sein","type":"array","required":false},"comments":{"description":"Kommentar-IDs sollen in der vollen Synchronisierung inbegriffen sein","type":"array","required":false},"context":{"description":"Kontext zur vollst\u00e4ndigen Synchronisation","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/full-sync"}]}},"\/jetpack\/v4\/sync\/status":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"fields":{"description":"Eine mit Kommas unterteilte Liste zus\u00e4tzlicher Felder, die im Status inbegriffen sein sollten.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/status"}]}},"\/jetpack\/v4\/sync\/health":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"description":"Neuer Zustand des Synchronisierungsstatus","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/health"}]}},"\/jetpack\/v4\/sync\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/settings"}]}},"\/jetpack\/v4\/sync\/object":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"module_name":{"description":"Name des Synchronisierungsmoduls","type":"string","required":false},"object_type":{"description":"Objekt-Typ","type":"string","required":false},"object_ids":{"description":"Eindeutige Kennungen der Objekte","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/object"}]}},"\/jetpack\/v4\/sync\/now":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Name der Synchronisierungs-Warteschlange.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/now"}]}},"\/jetpack\/v4\/sync\/checkout":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Name der Synchronisierungs-Warteschlange.","type":"string","required":false},"number_of_items":{"description":"Anzahl der Elemente, die aus der Warteschlange abgerufen werden sollen.","type":"integer","required":false},"pop":{"description":"Elemente aus der Warteschlange entnehmen, anstatt sie abzurufen.","type":"boolean","required":false},"force":{"description":"Erzwinge das Entsperren der Warteschlange vor dem Abruf.","type":"boolean","required":false},"encode":{"description":"Die Elemente vor dem Senden kodieren.","type":"boolean","default":true,"required":false},"use_memory_limit":{"description":"Verwende einen speicherbasierten Abruf anstelle einer festen Elementanzahl.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/checkout"}]}},"\/jetpack\/v4\/sync\/close":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/close"}]}},"\/jetpack\/v4\/sync\/unlock":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Name der Synchronisierungs-Warteschlange.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/unlock"}]}},"\/jetpack\/v4\/sync\/object-id-range":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"sync_module":{"description":"Name des Synchronisierungsmoduls.","type":"string","required":true},"batch_size":{"description":"Gr\u00f6\u00dfe der Batches","type":"int","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/object-id-range"}]}},"\/jetpack\/v4\/sync\/data-check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"perform_text_conversion":{"description":"Ob Textfelder bei Pr\u00fcfsummen-Berechnungen in latin1 konvertiert werden m\u00fcssen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/data-check"}]}},"\/jetpack\/v4\/sync\/data-histogram":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"columns":{"description":"Spaltenzuordnung","type":"array","required":false},"object_type":{"description":"Objekt-Typ","type":"string","required":false},"buckets":{"description":"Anzahl der Histogramm-Buckets.","type":"int","required":false},"start_id":{"description":"Start-ID f\u00fcr das Histogramm","type":"int","required":false},"end_id":{"description":"End-ID f\u00fcr das Histogramm","type":"int","required":false},"strip_non_ascii":{"description":"Nicht-ASCII-Zeichen entfernen?","type":"boolean","required":false},"shared_salt":{"description":"Beim Generieren der Pr\u00fcfsumme \u201eShared Salt\u201c verwenden","type":"string","required":false},"only_range_edges":{"description":"Sollen nur Randbereiche zur\u00fcckgegeben werden?","type":"boolean","required":false},"detailed_drilldown":{"description":"Was soll abgerufen werden: die Pr\u00fcfsumme oder die Objekt-IDs?","type":"boolean","required":false},"perform_text_conversion":{"description":"Ob Textfelder bei Pr\u00fcfsummen-Berechnungen in latin1 konvertiert werden m\u00fcssen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/data-histogram"}]}},"\/jetpack\/v4\/sync\/spawn-sync":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/spawn-sync"}]}},"\/jetpack\/v4\/sync\/locks":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/locks"}]}},"\/jetpack\/v4\/sync\/clear-queue":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/sync\/clear-queue"}]}},"\/jetpack\/v4\/jitm":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/jitm"}]}},"\/jetpack\/v4\/identity-crisis\/confirm-safe-mode":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/identity-crisis\/confirm-safe-mode"}]}},"\/jetpack\/v4\/identity-crisis\/migrate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/identity-crisis\/migrate"}]}},"\/jetpack\/v4\/identity-crisis\/start-fresh":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"redirect_uri":{"description":"URI der Administratorseite, auf die der Benutzer nach dem Verbinden weitergeleitet werden soll","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/identity-crisis\/start-fresh"}]}},"\/jetpack\/v4\/identity-crisis\/idc-url-validation":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/identity-crisis\/idc-url-validation"}]}},"\/jetpack\/v4\/identity-crisis\/url-secret":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/identity-crisis\/url-secret"}]}},"\/jetpack\/v4\/identity-crisis\/compare-url-secret":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"secret":{"description":"Geheime URL, um sie mit den in der Datenbank gespeicherten zu vergleichen.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/identity-crisis\/compare-url-secret"}]}},"\/jetpack\/v4\/search\/plan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/plan"}]}},"\/jetpack\/v4\/search\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/settings"}]}},"\/jetpack\/v4\/search\/stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/stats"}]}},"\/jetpack\/v4\/search\/pricing":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/pricing"}]}},"\/jetpack\/v4\/search\/templates\/(?P<post_type>[a-z0-9_-]+)":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"post_type":{"required":true}}}]},"\/jetpack\/v4\/search\/plan\/activate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/plan\/activate"}]}},"\/jetpack\/v4\/search\/plan\/activate-free":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"source":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/plan\/activate-free"}]}},"\/jetpack\/v4\/search\/plan\/deactivate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/plan\/deactivate"}]}},"\/jetpack\/v4\/search":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search"}]}},"\/jetpack\/v4\/search\/local-stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/search\/local-stats"}]}},"\/jetpack\/v4\/waf":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/waf"}]}},"\/jetpack\/v4\/waf\/update-rules":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/waf\/update-rules"}]}},"\/jetpack\/v4\/stats-app":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/stats-app","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/(?P<resource>[\\-\\w]+)\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/posts\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/posts\/(?P<resource_id>[\\d]+)\/likes":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/stats"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/site-has-never-published-post":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/site-has-never-published-post"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/posts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/posts"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/subscribers\/counts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/subscribers\/counts"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats\/usage":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats\/usage"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats\/settings":{"namespace":"jetpack\/v4\/stats-app","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"admin_bar":{"description":"Show a chart of the last 48 hours of views in the admin bar","type":"boolean","required":false},"roles":{"description":"Roles that can view Stats. `administrator` is always kept.","type":"array","items":{"type":"string"},"minItems":1,"required":false},"count_roles":{"description":"Roles whose logged-in page views are counted","type":"array","items":{"type":"string"},"required":false},"wpcom_reader_views_enabled":{"description":"Show post views in the WordPress.com Reader","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats\/settings"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats\/user-feedback":{"namespace":"jetpack\/v4\/stats-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats\/user-feedback"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/wordads\/earnings":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/wordads\/earnings"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/wordads\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/wordads\/stats"}]}},"\/jetpack\/v4\/stats-app\/stats\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":0,"description":"Postponed for (in seconds)","minimum":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/stats\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats-dashboard\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":0,"description":"Postponed for (in seconds)","minimum":0,"required":false}}},{"methods":["GET"],"args":{"include_details":{"type":"boolean","default":false,"description":"Return a detail record per notice instead of a flat boolean map","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats-dashboard\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/referrers\/spam":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/referrers\/spam"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/referrers\/spam\/new":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/referrers\/spam\/new"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/referrers\/spam\/delete":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/referrers\/spam\/delete"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats-dashboard\/modules":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats-dashboard\/modules"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats-dashboard\/module-settings":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/jetpack-stats-dashboard\/module-settings"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/emails\/(?P<resource>[\\-\\w\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/opens\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/clicks\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/(?P<resource>[\\-\\w]+)\/emails\/(?P<post_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/utm\/(?P<utm_params>[_,\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/devices\/(?P<device_property>[\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/24300995\/commercial-classification":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/commercial-classification"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/purchases":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats-app\/sites\/24300995\/purchases"}]}},"\/jetpack\/v4\/stats-app\/sites\/24300995\/stats\/location-views\/(?P<geo_mode>country|region|city)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/blaze-app","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app"}]}},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/blaze\/posts(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app\/sites\/24300995\/blaze\/posts(\\?.*)?"}]}},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/sites\/24300995\/blaze\/posts(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/sites\/24300995\/blaze\/posts(\\?.*)?"}]}},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/checkout":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/checkout"}]}},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/credits(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/sites\/24300995\/media(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/sites\/24300995\/media":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/sites\/24300995\/media"}]}},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/wpcom\/media(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/experiments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1.1\/campaigns":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1.1\/campaigns"}]}},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/sites\/24300995\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/stats(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/stats(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/search(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/user(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/templates\/article\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/templates\/advise\/campaign\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/templates(?P<sub_path>[a-zA-Z0-9-_\\\/:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/advise\/campaign\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/advise(?P<sub_path>[a-zA-Z0-9-_\\\/:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/subscriptions(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/subscriptions(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/payments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/payments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/smart(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/smart(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/locations(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/woo(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/image(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/logs":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze-app\/sites\/24300995\/wordads\/dsp\/api\/v1\/logs"}]}},"\/jetpack\/v4\/blaze":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/blaze","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze"}]}},"\/jetpack\/v4\/blaze\/eligibility":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze\/eligibility"}]}},"\/jetpack\/v4\/blaze\/dashboard":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze\/dashboard"}]}},"\/jetpack\/v4\/blaze\/active-campaigns":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/blaze\/active-campaigns"}]}},"\/jetpack\/v4\/activity-log":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Anzahl der Eintr\u00e4ge, die pro Seite zur\u00fcckgegeben werden sollen","type":"integer","minimum":1,"maximum":1000,"required":false},"page":{"description":"1-indexierte Seitenzahl.","type":"integer","minimum":1,"required":false},"sort_order":{"description":"Sortierrichtung.","type":"string","enum":["asc","desc"],"required":false},"after":{"description":"Untergrenze f\u00fcr Ereigniszeitstempel nach ISO 8601.","type":"string","format":"date-time","required":false},"before":{"description":"Obergrenze f\u00fcr den Ereigniszeitstempel nach ISO 8601.","type":"string","format":"date-time","required":false},"group":{"description":"Gibt nur Ereignisse in diesen Gruppen zur\u00fcck.","type":"array","items":{"type":"string"},"required":false},"not_group":{"description":"Ereignisse in diesen Gruppen ausschlie\u00dfen.","type":"array","items":{"type":"string"},"required":false},"text_search":{"description":"Volltext-Suchzeichenfolge.","type":"string","required":false},"actor":{"description":"Gibt nur Ereignisse zur\u00fcck, die von diesen Akteurs-IDs ausgef\u00fchrt werden.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/activity-log"}]}},"\/jetpack\/v4\/activity-log\/count\/group":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Begrenzung der Anzahl der Ereignisse, die beim Z\u00e4hlen von Gruppen ber\u00fccksichtigt werden.","type":"integer","minimum":1,"maximum":1000,"required":false},"after":{"description":"Untergrenze f\u00fcr Ereigniszeitstempel nach ISO 8601.","type":"string","format":"date-time","required":false},"before":{"description":"Obergrenze f\u00fcr den Ereigniszeitstempel nach ISO 8601.","type":"string","format":"date-time","required":false},"group":{"description":"Nur Ereignisse in diesen Gruppen z\u00e4hlen.","type":"array","items":{"type":"string"},"required":false},"not_group":{"description":"Ereignisse in diesen Gruppen ausschlie\u00dfen.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/activity-log\/count\/group"}]}},"\/jetpack\/v4\/activity-log\/actors":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Begrenzt die Anzahl der Ereignisse, die beim Sammeln von Akteuren ber\u00fccksichtigt werden.","type":"integer","minimum":1,"maximum":1000,"required":false},"after":{"description":"Untergrenze f\u00fcr Ereigniszeitstempel nach ISO 8601.","type":"string","format":"date-time","required":false},"before":{"description":"Obergrenze f\u00fcr den Ereigniszeitstempel nach ISO 8601.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/activity-log\/actors"}]}},"\/jetpack\/v4\/feature\/custom-content-types":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/feature\/custom-content-types"}]}},"\/jetpack\/v4\/hints":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"hint":{"default":"","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/hints"}]}},"\/rankmath\/v1\/ai-visibility":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ai-visibility","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ai-visibility"}]}},"\/rankmath\/v1\/ai-visibility\/overview":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"refresh":{"description":"Aktualisierung \u00fcber die AI Visibility API erzwingen.","type":"boolean","default":false,"required":false},"search":{"description":"Marken nach Name oder URL filtern.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ai-visibility\/overview"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Marken-UUID.","type":"string","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Marken-UUID.","type":"string","required":true},"name":{"type":"string","required":false},"url":{"type":"string","required":false},"description":{"type":"string","required":false},"locale":{"type":"string","required":false},"language":{"type":"string","enum":["","US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":false},"status":{"type":"string","enum":["active","inactive"],"required":false},"interval":{"type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"KI-Plattformen, die f\u00fcr diese Marke verfolgt werden sollen. Unterst\u00fctzte Werte: \"chatgpt\", \"gemini\". F\u00fcr mehr als eine Plattform pro Marke ist der Expert-Tarif erforderlich.","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"name":{"description":"Markenname.","type":"string","required":true},"url":{"description":"Website-URL oder Domain der Marke.","type":"string","required":true},"description":{"description":"Kurzbeschreibung der Marke oder des Produkts.","type":"string","required":true},"locale":{"description":"L\u00e4ndercode nach ISO 3166-1 Alpha-2 (z. B. &quot;US&quot;, &quot;HU&quot;).","type":"string","required":false},"language":{"description":"Ausgabesprache f\u00fcr die Analyse und Erstellung von Inhalten dieser Marke. Unabh\u00e4ngig von `locale` (Zielland). Erforderlich und nach dem Erstellen nicht \u00e4nderbar.","type":"string","enum":["US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":true},"interval":{"description":"H\u00e4ufigkeit der Aktualisierung der Analyse. Bei Auslassung verwendet das Backend den Standardwert des Kontotarifs.","type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"KI-Plattformen, die f\u00fcr diese Marke verfolgt werden sollen. Unterst\u00fctzte Werte: \"chatgpt\", \"gemini\". F\u00fcr mehr als eine Plattform pro Marke ist der Expert-Tarif erforderlich.","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ai-visibility\/brands"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/insights":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Marken-UUID.","type":"string","required":true}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Marken-UUID.","type":"string","required":true}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries\/(?P<qid>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Marken-UUID.","type":"string","required":true},"qid":{"description":"UUID der Suchanfrage.","type":"string","required":true},"enabled":{"description":"Ob die Suchanfrage f\u00fcr Analysen aktiviert ist.","type":"boolean","required":true}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/generate-queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Marken-UUID.","type":"string","required":true}}}]},"\/rankmath\/v1\/ai-visibility\/trial\/activate":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ai-visibility\/trial\/activate"}]}},"\/rankmath\/v1\/ai-visibility\/checkout-url":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ai-visibility\/checkout-url"}]}},"\/rankmath\/v1\/ca":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ca","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca"}]}},"\/rankmath\/v1\/ca\/researchKeyword":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"Das zu recherchierende Schl\u00fcsselwort.","type":"string","required":true},"country":{"description":"Das Land, f\u00fcr das das Schl\u00fcsselwort recherchiert werden soll.","type":"string","required":true},"objectID":{"description":"Die ID des Beitrags, der die Schl\u00fcsselwort-Rechercheanfrage initiiert.","type":"integer","required":true},"force_update":{"description":"Wenn dies zutrifft, wird eine neue Forschungsanfrage erzwungen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/researchKeyword"}]}},"\/rankmath\/v1\/ca\/getCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/getCredits"}]}},"\/rankmath\/v1\/ca\/createPost":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"content":{"description":"Der Inhalt des neuen Beitrags.","type":"string","required":true},"title":{"description":"Der Titel des neuen Beitrags.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/createPost"}]}},"\/rankmath\/v1\/ca\/saveOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"outputs":{"description":"Eine Reihe von KI-generierten und vorhandenen Ausgaben, die gespeichert werden sollen.","type":"array","required":false},"endpoint":{"description":"Der API-Endpunkt, f\u00fcr den die Ausgabe generiert wurde.","type":"string","required":false},"isChat":{"description":"Gibt an, ob die Anforderung f\u00fcr den Chat-Endpunkt war.","type":"boolean","required":false},"attributes":{"description":"Die Parameter, die zum Generieren der KI-Ausgabe verwendet werden.","type":"object","required":false},"credits":{"description":"Von der API zur\u00fcckgegebene Details zur Kreditnutzung.","type":"object","required":false},"usage":{"description":"Nutzungsdaten pro Tool, bereitgestellt durch die API.","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/saveOutput"}]}},"\/rankmath\/v1\/ca\/deleteOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"isChat":{"description":"Gibt an, ob die Anforderung zum L\u00f6schen der Ausgabe f\u00fcr den Chat-Endpunkt war.","type":"boolean","required":false},"index":{"description":"Der zu l\u00f6schende Ausgabeindex, gilt nur f\u00fcr den Chat-Endpunkt.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/deleteOutput"}]}},"\/rankmath\/v1\/ca\/updateRecentPrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"Die ausgew\u00e4hlte Eingabeaufforderung soll in den letzten Eingabeaufforderungen aktualisiert werden.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/updateRecentPrompt"}]}},"\/rankmath\/v1\/ca\/updatePrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"Die Eingabeaufforderungsdaten, die in der Datenbank gespeichert werden sollen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/updatePrompt"}]}},"\/rankmath\/v1\/ca\/savePrompts":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompts":{"description":"Eine Liste der von der API empfangenen Eingabeaufforderungen, die in der Datenbank gespeichert werden sollen.","type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/savePrompts"}]}},"\/rankmath\/v1\/ca\/pingContentAI":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"plan":{"description":"In der Datenbank zu aktualisierender Rank Math AI-Tarif.","type":"string","required":true},"refreshDate":{"description":"Datum f\u00fcr das Zur\u00fccksetzen der Inhalt-KI zur Aktualisierung in der Datenbank","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/pingContentAI"}]}},"\/rankmath\/v1\/ca\/generateAlt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"attachmentIds":{"description":"Liste der Anhangs-IDs, f\u00fcr die Alternativtext generiert werden soll.","type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/generateAlt"}]}},"\/rankmath\/v1\/ca\/updateCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"credits":{"description":"Von der API zur\u00fcckgegebene Details zur Kreditnutzung.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/ca\/updateCredits"}]}},"\/rankmath\/v1\/an":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/an","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an"}]}},"\/rankmath\/v1\/an\/dashboard":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/dashboard"}]}},"\/rankmath\/v1\/an\/keywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/keywordsOverview"}]}},"\/rankmath\/v1\/an\/postsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/postsSummary"}]}},"\/rankmath\/v1\/an\/postsRowsByObjects":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Seitenzahl.","type":"integer","required":false},"per_page":{"description":"Ergebnisse pro Seite.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/postsRowsByObjects"}]}},"\/rankmath\/v1\/an\/post\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Beitrags-ID.","type":"integer","required":true}}}]},"\/rankmath\/v1\/an\/keywordsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/keywordsSummary"}]}},"\/rankmath\/v1\/an\/analyticsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postType":{"description":"Beitragstyp.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/analyticsSummary"}]}},"\/rankmath\/v1\/an\/keywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Seitenzahl.","type":"integer","required":false},"perPage":{"description":"Ergebnisse pro Seite.","type":"integer","required":false},"orderBy":{"description":"Bestellung bis.","type":"string","required":false},"order":{"description":"Bestellen.","type":"string","required":false},"search":{"description":"Suchen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/keywordsRows"}]}},"\/rankmath\/v1\/an\/userPreferences":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"preferences":{"description":"Benutzer-Einstellungen.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/userPreferences"}]}},"\/rankmath\/v1\/an\/inspectionResults":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Seitenzahl.","type":"integer","required":false},"perPage":{"description":"Ergebnisse pro Seite.","type":"integer","required":false},"orderBy":{"description":"Bestellung bis.","type":"string","required":false},"order":{"description":"Bestellen.","type":"string","required":false},"search":{"description":"Suchen.","type":"string","required":false},"filter":{"description":"Filter.","type":"string","required":false},"filterType":{"description":"Filter-Typ.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/inspectionResults"}]}},"\/rankmath\/v1\/an\/removeFrontendStats":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"toggleBar":{"description":"Umschaltleiste.","type":"boolean","required":false},"hide":{"description":"Verbergen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/an\/removeFrontendStats"}]}},"\/rankmath\/v1\/in":{"namespace":"rankmath\/v1\/in","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/in","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/in"}]}},"\/rankmath\/v1\/in\/submitUrls":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"urls":{"description":"Die Liste der URLs, die an die Instant Indexing API \u00fcbermittelt werden sollen.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/in\/submitUrls"}]}},"\/rankmath\/v1\/in\/getLog":{"namespace":"rankmath\/v1\/in","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filter":{"description":"Filter das Protokoll nach Typ.","type":"string","enum":["all","manual","auto"],"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/in\/getLog"}]}},"\/rankmath\/v1\/in\/clearLog":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filter":{"description":"Protokoll nach Typ l\u00f6schen.","type":"string","enum":["all","manual","auto"],"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/in\/clearLog"}]}},"\/rankmath\/v1\/in\/resetKey":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/in\/resetKey"}]}},"\/rankmath\/v1\/links\/posts":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Seitenzahl.","type":"integer","default":1,"required":false},"per_page":{"description":"Elemente pro Seite.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Im Beitragstitel suchen.","type":"string","default":"","required":false},"post_type":{"description":"Nach Beitragstyp filtern. Mehrere Werte werden unterst\u00fctzt.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Nach Verwaistheitsstatus filtern (verwaist, verlinkt)","type":"string","default":"","required":false},"seo_score_range":{"description":"Nach SEO-Score-Bereich filtern (sehr gut, gut, schlecht, kein Score).","type":"string","default":"","required":false},"post_id":{"description":"Nach Beitrags-ID filtern.","type":"integer","default":0,"required":false},"orderby":{"description":"Nach Feld sortieren.","type":"string","default":"post_title","required":false},"order":{"description":"Sortierrichtung (aufsteigend, absteigend).","type":"string","default":"ASC","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/links\/posts"}]}},"\/rankmath\/v1\/links\/posts-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/links\/posts-stats"}]}},"\/rankmath\/v1\/links\/links":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Seitenzahl.","type":"integer","default":1,"required":false},"per_page":{"description":"Elemente pro Seite.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"In der URL suchen.","type":"string","default":"","required":false},"source_id":{"description":"Nach Quell-Beitrags-ID filtern.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Nach Ziel-Beitrags-ID filtern","type":"integer","default":0,"required":false},"is_internal":{"description":"Nach Linktyp filtern (1 = intern, 0 = extern).","type":"string","default":"","required":false},"orderby":{"description":"Nach Feld sortieren.","type":"string","default":"id","required":false},"order":{"description":"Sortierrichtung (aufsteigend, absteigend).","type":"string","default":"DESC","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/links\/links"}]}},"\/rankmath\/v1\/links\/links-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/links\/links-stats"}]}},"\/rankmath\/v1\/status":{"namespace":"rankmath\/v1\/status","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/status","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/status"}]}},"\/rankmath\/v1\/status\/getViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/status\/getViewData"}]}},"\/rankmath\/v1\/status\/updateViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/status\/updateViewData"}]}},"\/rankmath\/v1\/status\/importSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/status\/importSettings"}]}},"\/rankmath\/v1\/status\/exportSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/status\/exportSettings"}]}},"\/rankmath\/v1\/status\/runBackup":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/rankmath\/v1\/status\/runBackup"}]}},"\/jetpack\/v4\/backups":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/backups"}]}},"\/jetpack\/v4\/backup-capabilities":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/backup-capabilities"}]}},"\/jetpack\/v4\/has-backup-plan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/has-backup-plan"}]}},"\/jetpack\/v4\/restores":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/restores"}]}},"\/jetpack\/v4\/site\/current-purchases":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/current-purchases"}]}},"\/jetpack\/v4\/backup-promoted-product-info":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/backup-promoted-product-info"}]}},"\/jetpack\/v4\/site\/dismissed-review-request":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"option_name":{"type":"string","enum":["restore","backups"],"required":true},"should_dismiss":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/dismissed-review-request"}]}},"\/jetpack\/v4\/site\/backup\/size":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/size"}]}},"\/jetpack\/v4\/site\/backup\/schedule":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/schedule"}]}},"\/jetpack\/v4\/site\/backup\/policies":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/policies"}]}},"\/jetpack\/v4\/site\/backup\/addon-offer":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"storage_size":{"type":"numeric","required":true},"storage_limit":{"type":"numeric","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/addon-offer"}]}},"\/jetpack\/v4\/site\/backup\/enqueue":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site\/backup\/enqueue"}]}},"\/jetpack\/v4\/import":{"namespace":"jetpack\/v4\/import","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/import","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import"}]}},"\/jetpack\/v4\/import\/blocks":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/blocks"}]}},"\/jetpack\/v4\/import\/categories":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die \u00fcbergeordnete Kategorie-Titelform","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/categories"}]}},"\/jetpack\/v4\/import\/comments":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/comments"}]}},"\/jetpack\/v4\/import\/custom-css":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/custom-css"}]}},"\/jetpack\/v4\/import\/end":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/end"}]}},"\/jetpack\/v4\/import\/global-styles":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"theme":{"description":"Der Name des Themes.","type":"string","required":true},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/global-styles"}]}},"\/jetpack\/v4\/import\/media":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"upload_date":{"description":"Das Datum f\u00fcr das Upload-Verzeichnis des Anhangs.","type":["string","null"],"pattern":"^\\d{4}\\\/\\d{2}$","required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Ob Bilduntergr\u00f6\u00dfen erzeugt werden sollen.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Ob Bildformate konvertiert werden sollen.","required":false},"url":{"type":"string","format":"uri","description":"Die URL eines externen Bildes, das in die Mediathek \u00fcbertragen werden soll, anstatt eine Datei hochzuladen.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/media"}]}},"\/jetpack\/v4\/import\/media\/(?P<id>[\\d]+)":{"namespace":"jetpack\/v4\/import","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"upload_date":{"description":"Das Datum f\u00fcr das Upload-Verzeichnis des Anhangs.","type":["string","null"],"pattern":"^\\d{4}\\\/\\d{2}$","required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}}]},"\/jetpack\/v4\/import\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/jetpack\/v4\/import\/menu-items":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Titelform des \u00fcbergeordneten Men\u00fcs.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/menu-items"}]}},"\/jetpack\/v4\/import\/menus":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/menus"}]}},"\/jetpack\/v4\/import\/navigation":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/navigation"}]}},"\/jetpack\/v4\/import\/pages":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"items":{"type":"string"},"required":false},"tags":{"items":{"type":"string"},"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/pages"}]}},"\/jetpack\/v4\/import\/posts":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Ob der Beitrag jemals ver\u00f6ffentlicht wurde.","default":false}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/posts"}]}},"\/jetpack\/v4\/import\/start":{"namespace":"jetpack\/v4\/import","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/start"}]}},"\/jetpack\/v4\/import\/tags":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/tags"}]}},"\/jetpack\/v4\/import\/template-parts":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/template-parts"}]}},"\/jetpack\/v4\/import\/templates":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"unified_importer_id":{"description":"Die eindeutige Jetpack-Import-Kennung f\u00fcr den Begriff.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/import\/templates"}]}},"\/wpcom\/v2":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2"}]}},"\/wpcom\/v2\/videopress\/meta":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die Beitrags-ID f\u00fcr den Anhang.","type":"integer","required":true},"title":{"description":"Der Titel des Videos.","type":"string","required":false},"description":{"description":"Die Beschreibung des Videos.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Videos.","type":"string","required":false},"rating":{"description":"Die Bewertung des Videoinhalts. FSK ab 0 freigegeben, FSK ab 12 freigegeben oder FSK ab 18 freigegeben","type":"string","required":false},"display_embed":{"description":"Zeige das Men\u00fc zum Teilen im Player an.","type":"boolean","required":false},"allow_download":{"description":"Die Download-Option anzeigen und es Besuchern erm\u00f6glichen, dieses Video herunterzuladen","type":"boolean","required":false},"privacy_setting":{"description":"So legst du fest, ob das Video \u00f6ffentlich oder privat sein soll","type":"integer","enum":[0,1,2],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/videopress\/meta"}]}},"\/wpcom\/v2\/videopress\/(?P<video_guid>[A-Za-z0-9]{8})\/poster":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"video_guid":{"description":"Der VideoPress-GUID.","type":"string","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"video_guid":{"description":"Der VideoPress-GUID.","type":"string","required":true},"at_time":{"description":"Der Zeitpunkt in dem Video, der als Titelbild verwendet werden soll.","type":"integer","required":false},"is_millisec":{"description":"Ob die Zeit in Millisekunden oder Sekunden angegeben ist.","type":"boolean","required":false},"poster_attachment_id":{"description":"Die Anhang-ID des Vorschaubilds.","type":"integer","required":false}}}]},"\/wpcom\/v2\/videopress\/(?P<video_guid>[A-Za-z0-9]{8})\/check-ownership\/(?P<post_id>\\d+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"video_guid":{"description":"Der VideoPress-GUID.","type":"string","required":true},"post_id":{"description":"Die Beitrags-ID f\u00fcr den Anhang.","type":"integer","required":true}}}]},"\/wpcom\/v2\/videopress\/upload-jwt":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/videopress\/upload-jwt"}]}},"\/wpcom\/v2\/videopress\/playback-jwt\/(?P<video_guid>[A-Za-z0-9]{8})":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"video_guid":{"description":"Der VideoPress-GUID.","type":"string","required":true},"post_id":{"description":"Der Beitrag, in den das Video eingebettet ist, um den Zugriff zu autorisieren.","type":"integer","required":false},"subscription_plan_id":{"description":"Der Abonnement-Tarif, den der Block f\u00fcr Premium-Inhalte mit dem Video verwendet.","type":"integer","required":false}}}]},"\/wpcom\/v2\/videopress\/settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"videopress_videos_private_for_site":{"description":"Wenn die VideoPress-Videos standardm\u00e4\u00dfig privat sein sollten","type":"boolean","required":false},"videopress_auto_subtitles_disabled":{"description":"Ob automatisch generierte Untertitel f\u00fcr neue Videos \u00fcbersprungen werden sollen","type":"boolean","required":false},"videopress_player_preload_disabled":{"description":"Ob eingebettete Player vor dem Vorladen von Videodaten auf die Wiedergabe warten sollen","type":"boolean","required":false},"videopress_inline_player_enabled":{"description":"Ob Videos einen Inline-Player aus einem gemeinsam genutzten Skript anstelle eines Frames pro Video wiedergeben sollen","type":"boolean","required":false},"videopress_share_menu_disabled":{"description":"Ob das Teilen-Men\u00fc bei jedem Video ausgeblendet werden soll, wobei die Einstellungen jedes Videos \u00fcberschrieben werden","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/videopress\/settings"}]}},"\/wpcom\/v2\/videopress\/promote\/(?P<attachment_id>\\d+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attachment_id":{"description":"Die Anhangs-ID des Videos, das ver\u00f6ffentlicht werden soll.","type":"integer","required":true}}}]},"\/wpcom\/v2\/videopress\/caption-tracks":{"namespace":"wpcom\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"guid":{"description":"VideoPress-GUID.","type":"string","required":true}}},{"methods":["POST"],"args":{"guid":{"description":"VideoPress-GUID.","type":"string","required":false},"title":{"description":"Titel der Untertitelspur.","type":"string","required":false},"content":{"description":"Serialisierter Blockinhalt f\u00fcr Bildunterschriften.","type":"string","required":false},"status":{"description":"Status der Untertitelspur.","type":"string","enum":["draft","publish"],"required":false},"meta":{"description":"Metadaten der Untertitelspur.","type":"object","properties":{"_videopress_guid":{"type":"string"},"_videopress_caption_kind":{"type":"string"},"_videopress_caption_src_lang":{"type":"string"},"_videopress_caption_label":{"type":"string"},"_videopress_source_track_kind":{"type":"string"},"_videopress_source_track_src_lang":{"type":"string"},"_videopress_source_track_src":{"type":"string"}},"additionalProperties":false,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/videopress\/caption-tracks"}]}},"\/wpcom\/v2\/videopress\/caption-tracks\/(?P<id>\\d+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Untertitelspur-ID.","type":"integer","required":true},"guid":{"description":"VideoPress-GUID.","type":"string","required":false},"title":{"description":"Titel der Untertitelspur.","type":"string","required":false},"content":{"description":"Serialisierter Blockinhalt f\u00fcr Bildunterschriften.","type":"string","required":false},"status":{"description":"Status der Untertitelspur.","type":"string","enum":["draft","publish"],"required":false},"meta":{"description":"Metadaten der Untertitelspur.","type":"object","properties":{"_videopress_guid":{"type":"string"},"_videopress_caption_kind":{"type":"string"},"_videopress_caption_src_lang":{"type":"string"},"_videopress_caption_label":{"type":"string"},"_videopress_source_track_kind":{"type":"string"},"_videopress_source_track_src_lang":{"type":"string"},"_videopress_source_track_src":{"type":"string"}},"additionalProperties":false,"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Untertitelspur-ID.","type":"integer","required":true}}}]},"\/jetpack\/v4\/stats\/blog":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/stats\/blog"}]}},"\/jetpack-boost\/v1":{"namespace":"jetpack-boost\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack-boost\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack-boost\/v1"}]}},"\/jetpack-boost\/v1\/speed-scores":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack-boost\/v1\/speed-scores"}]}},"\/jetpack-boost\/v1\/speed-scores\/refresh":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack-boost\/v1\/speed-scores\/refresh"}]}},"\/jetpack-boost\/v1\/speed-scores-history":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack-boost\/v1\/speed-scores-history"}]}},"\/my-jetpack\/v1":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"my-jetpack\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1"}]}},"\/my-jetpack\/v1\/site\/products":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"products":{"description":"Eine mit Kommas unterteilte Liste mit Produkttitelformen, die abgerufen werden sollen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products"}]}},"\/my-jetpack\/v1\/site\/products\/install":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Array von Produkttitelformen","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","activity-log","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products\/install"}]}},"\/my-jetpack\/v1\/site\/products\/activate":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Array von Produkttitelformen","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","activity-log","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products\/activate"}]}},"\/my-jetpack\/v1\/site\/products\/search\/activate-free":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"source":{"description":"Wo die Aktivierung angefordert wurde.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products\/search\/activate-free"}]}},"\/my-jetpack\/v1\/site\/products\/interstitials":{"namespace":"my-jetpack\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Schl\u00fcssel-Wert-Paare von Produkt-Titelformen und ihre Interstitial-Status.","type":"object","properties":{"anti-spam":{"type":"boolean"},"backup":{"type":"boolean"},"boost":{"type":"boolean"},"crm":{"type":"boolean"},"creator":{"type":"boolean"},"extras":{"type":"boolean"},"jetpack-ai":{"type":"boolean"},"ai":{"type":"boolean"},"scan":{"type":"boolean"},"search":{"type":"boolean"},"social":{"type":"boolean"},"security":{"type":"boolean"},"protect":{"type":"boolean"},"videopress":{"type":"boolean"},"stats":{"type":"boolean"},"growth":{"type":"boolean"},"complete":{"type":"boolean"},"activity-log":{"type":"boolean"},"newsletter":{"type":"boolean"},"site-accelerator":{"type":"boolean"},"related-posts":{"type":"boolean"},"jetpack-forms":{"type":"boolean"}},"additionalProperties":false,"minProperties":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products\/interstitials"}]}},"\/my-jetpack\/v1\/site\/products\/deactivate":{"namespace":"my-jetpack\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"products":{"description":"Array von Produkttitelformen","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","activity-log","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products\/deactivate"}]}},"\/my-jetpack\/v1\/site\/products-ownership":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/products-ownership"}]}},"\/my-jetpack\/v1\/site\/purchases":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/purchases"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"goals":{"description":"Liste der vom Benutzer ausgew\u00e4hlten Ziele.","type":"array","items":{"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"recommendations":{"description":"Empfohlene Modul-Titelformen, die ihrer Bewertung zugeordnet sind.","type":"object","additionalProperties":{"type":"number"},"required":true}}},{"methods":["DELETE"],"args":{"showWelcomeBanner":{"description":"Ob das Willkommensbanner erneut angezeigt werden soll.","type":"string","enum":["true","false"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result"}]}},"\/wpcom\/v2\/my-jetpack\/site\/features":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/my-jetpack\/site\/features"}]}},"\/wpcom\/v2\/my-jetpack\/site\/features\/banner\/dismiss":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/my-jetpack\/site\/features\/banner\/dismiss"}]}},"\/wpcom\/v2\/my-jetpack\/site\/features\/plugin":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugin":{"type":"string","enum":["jetpack","akismet","jetpack-backup","blaze-ads","jetpack-boost","zero-bs-crm","jetpack-protect","jetpack-search","jetpack-social","jetpack-stats","jetpack-videopress"],"required":true},"action":{"type":"string","enum":["install","activate","deactivate"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/my-jetpack\/site\/features\/plugin"}]}},"\/wpcom\/v2\/my-jetpack\/site\/features\/bulk":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"plugins":{"type":"array","default":[],"items":{"type":"string","enum":["jetpack","akismet","jetpack-backup","blaze-ads","jetpack-boost","zero-bs-crm","jetpack-protect","jetpack-search","jetpack-social","jetpack-stats","jetpack-videopress"]},"required":false},"modules":{"type":"array","default":[],"items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/my-jetpack\/site\/features\/bulk"}]}},"\/my-jetpack\/v1\/site\/backup\/undo-event":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/backup\/undo-event"}]}},"\/my-jetpack\/v1\/site\/protect\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/protect\/data"}]}},"\/my-jetpack\/v1\/site\/videopress\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/videopress\/data"}]}},"\/my-jetpack\/v1\/site\/update-historically-active-modules":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/update-historically-active-modules"}]}},"\/my-jetpack\/v1\/jetpack-manage\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/jetpack-manage\/data"}]}},"\/my-jetpack\/v1\/jetpack-manage\/dismiss-banner":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/jetpack-manage\/dismiss-banner"}]}},"\/my-jetpack\/v1\/red-bubble-notifications":{"namespace":"my-jetpack\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dismissal_cookies":{"type":"array","description":"Array of dismissal cookies to set for the red bubble notifications.","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/red-bubble-notifications"}]}},"\/my-jetpack\/v1\/site":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site"}]}},"\/my-jetpack\/v1\/site\/dismiss-welcome-banner":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/my-jetpack\/v1\/site\/dismiss-welcome-banner"}]}},"\/jetpack\/v4\/explat":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/explat","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/explat"}]}},"\/jetpack\/v4\/explat\/assignments":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"experiment_name":{"type":"string","required":false},"anon_id":{"type":"string","required":false},"as_connected_user":{"type":"boolean","required":false},"platform":{"type":"string","enum":["jetpack","calypso","wpcom"],"default":"jetpack","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/explat\/assignments"}]}},"\/wpcom\/v2\/business-hours\/localized-week":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/business-hours\/localized-week"}]}},"\/wpcom\/v2\/admin-bar":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/admin-bar"}]}},"\/wpcom\/v2\/admin-color":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/admin-color"}]}},"\/wpcom\/v2\/admin-menu":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/admin-menu"}]}},"\/wpcom\/v2\/jetpack-ai\/feature-settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"master_enabled":{"type":"boolean","required":false},"features":{"type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/jetpack-ai\/feature-settings"}]}},"\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature"}]}},"\/wpcom\/v2\/app-media":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Anzahl der Medienelemente in der Anfrage","type":"number","default":20,"required":false},"page_handle":{"type":"number","default":1,"required":false},"after":{"description":"Zeitstempel seit dem Hochladen der Medien","type":"number","default":0,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/app-media"}]}},"\/wpcom\/v2\/application-password-extras\/abilities":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/application-password-extras\/abilities"}]}},"\/wpcom\/v2\/application-password-extras\/admin-ajax":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/application-password-extras\/admin-ajax"}]}},"\/wpcom\/v2\/editor-assets":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"exclude":{"description":"Durch Kommas getrennte Liste von Asset-Typen, die aus der Antwort ausgeschlossen werden sollen. Unterst\u00fctzte Werte: \u201ecore\u201c (WordPress Core-Assets), \u201egutenberg\u201c (Gutenberg Plugin-Assets) oder Plugin-Handle-Pr\u00e4fixe (z.\u00a0B. \u201econtact-form-7\u201c).","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/editor-assets"}]}},"\/wpcom\/v2\/blog-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"description":"Beitrags-ID, f\u00fcr die Statistiken angezeigt werden.","type":["string","integer"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/blog-stats"}]}},"\/wpcom\/v2\/email-editor-bootstrap":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"template_slug":{"description":"Titelform des E-Mail-Templates, das im Editor ge\u00f6ffnet werden soll.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"design":{"description":"Das zu speichernde E-Mail-Designdokument.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/email-editor-bootstrap"}]}},"\/wpcom\/v2\/email-preview":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"access":{"description":"Zugriffsebene.","enum":["everybody","subscribers","paid_subscribers"],"default":"everybody","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/email-preview"}]}},"\/wpcom\/v2\/external-media\/list\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"description":"Suchbegriff f\u00fcr Mediensammlung.","type":"string","required":false},"number":{"description":"Anzahl der Medienelemente in der Anfrage","type":"number","default":20,"required":false},"path":{"type":"string","required":false},"page_handle":{"type":"string","required":false},"session_id":{"description":"Sitzungs-ID eines Diensts\u00a0\u2013 derzeit nur Google Photos Picker","type":"string","required":false}}}]},"\/wpcom\/v2\/external-media\/copy\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"media":{"description":"Medientyp, der kopiert werden soll.","items":{"type":"array","items":{"type":"object","required":true,"properties":{"caption":{"type":"string"},"guid":{"type":"object","properties":{"caption":{"type":"string"},"name":{"type":"string"},"title":{"type":"string"},"url":{"format":"uri","type":"string"}}},"title":{"type":"string"},"meta":{"type":"object","additionalProperties":false,"properties":{"vertical_id":{"type":"string","format":"text-field"},"pexels_object":{"type":"object"}}}}}},"type":"array","required":true},"post_id":{"description":"Die Beitrags-ID, an die der Upload angeh\u00e4ngt wird","type":"number","minimum":0,"required":false},"should_proxy":{"description":"Gibt an, ob die Medienanfrage \u00fcber einen Proxy erfolgen soll.","type":"boolean","default":false,"required":false}}}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)\/picker_status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)\/(?P<session_id>.*)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/wpcom\/v2\/external-media\/proxy\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"url":{"type":"string","required":true}}}]},"\/wpcom\/v2\/following\/mine":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ignore_user_blogs":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/following\/mine"}]}},"\/wpcom\/v2\/following\/recommendations":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"type":"number","default":5,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/following\/recommendations"}]}},"\/wpcom\/v2\/goodreads\/user-id":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Goodreads-Benutzer-ID","type":"integer","minimum":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/goodreads\/user-id"}]}},"\/wpcom\/v2\/checkGoogleDocVisibility":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/checkGoogleDocVisibility"}]}},"\/wpcom\/v2\/instagram-gallery\/connect-url":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/instagram-gallery\/connect-url"}]}},"\/wpcom\/v2\/instagram-gallery\/connections":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/instagram-gallery\/connections"}]}},"\/wpcom\/v2\/instagram-gallery\/gallery":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"access_token":{"description":"Ein Instagram Keyring-Zugriffstoken.","type":"integer","minimum":1,"required":true},"count":{"description":"Wie viele Instagram-Beitr\u00e4ge?","type":"integer","minimum":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/instagram-gallery\/gallery"}]}},"\/wpcom\/v2\/mailchimp":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/mailchimp"}]}},"\/wpcom\/v2\/mailchimp\/groups":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/mailchimp\/groups"}]}},"\/wpcom\/v2\/mailchimp\/settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"follower_list_id":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/mailchimp\/settings"}]}},"\/wpcom\/v2\/jetpack-ai\/mcp-settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"mcp_abilities":{"type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/jetpack-ai\/mcp-settings"}]}},"\/wpcom\/v2\/newsletter-categories":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/newsletter-categories"}]}},"\/wpcom\/v2\/newsletter-categories\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term_ids":{"default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/newsletter-categories\/count"}]}},"\/wpcom\/v2\/newsletter-categories\/subscriptions\/(?P<subscription_id>[0-9]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"required":true},"type":{"required":false}}}]},"\/wpcom\/v2\/newsletter-email-sent-status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/newsletter-email-sent-status"}]}},"\/wpcom\/v2\/podcast-player":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die RSS-Feed-URL f\u00fcr den Podcast.","type":"string","required":true},"guids":{"description":"Eine Liste eindeutiger Kennungen f\u00fcr den Abruf bestimmter Podcast-Folgen.","type":"array","required":true},"episode-options":{"description":"Ob die Liste der Folgen zur Auswahl in der Benutzeroberfl\u00e4che ausgegeben werden soll","type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/podcast-player"}]}},"\/wpcom\/v2\/podcast-player\/track-quantity":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/podcast-player\/track-quantity"}]}},"\/wpcom\/v2\/profile":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/profile"}]}},"\/wpcom\/v2\/related-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/related-posts"}]}},"\/wpcom\/v2\/related-posts\/enable":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/related-posts\/enable"}]}},"\/wpcom\/v2\/related-posts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false}}}]},"\/wpcom\/v2\/resolve-redirect\/?(?P<url>.+)?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL; die auf Weiterleitungen \u00fcberpr\u00fcft wird.","type":"string","required":true}}}]},"\/wpcom\/v2\/search":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/search"}]}},"\/wpcom\/v2\/send-email-preview":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"email":{"description":"Optionale Empf\u00e4ngeradresse. Standardm\u00e4\u00dfig wird der aktuelle Benutzer verwendet. Eine andere Adresse wird nur von Benutzern akzeptiert, die Abonnenten hinzuf\u00fcgen k\u00f6nnen, und unterliegt denselben Missbrauchspr\u00fcfungen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/send-email-preview"}]}},"\/wpcom\/v2\/subscribers\/add":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"emails":{"type":"array","items":{"type":"string"},"required":true},"categories":{"type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/add"}]}},"\/wpcom\/v2\/subscribers\/remove":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"integer","default":0,"minimum":0,"required":false},"email_subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"paid_subscription_ids":{"type":"array","items":{"type":"string"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/remove"}]}},"\/wpcom\/v2\/subscribers\/individual":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"user_id":{"type":"integer","default":0,"minimum":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/individual"}]}},"\/wpcom\/v2\/subscribers\/individual-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"user_id":{"type":"integer","default":0,"minimum":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/individual-stats"}]}},"\/wpcom\/v2\/subscribers\/import":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/import"}]}},"\/wpcom\/v2\/subscribers\/import\/reset-state":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/import\/reset-state"}]}},"\/wpcom\/v2\/subscribers\/totals":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/totals"}]}},"\/wpcom\/v2\/subscribers\/list":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"sort":{"type":"string","default":"date_subscribed","enum":["date_subscribed","name","plan","subscription_status"],"required":false},"sort_order":{"type":"string","default":"desc","enum":["asc","desc"],"required":false},"search":{"type":"string","default":"","required":false},"filters":{"type":"array","items":{"type":"string"},"default":["all"],"required":false},"use_new_helper":{"type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/list"}]}},"\/wpcom\/v2\/subscribers\/products":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/products"}]}},"\/wpcom\/v2\/subscribers\/comp":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"integer","minimum":1,"required":true},"plan_id":{"type":"integer","minimum":1,"required":true},"no_expiration":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/comp"}]}},"\/wpcom\/v2\/subscribers\/remove-comp":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"comp_id":{"type":"integer","minimum":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/remove-comp"}]}},"\/wpcom\/v2\/template-loader\/(?P<template_type>\\w+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"template_type":{"description":"Die Art des Templates.","type":"string","required":true}}}]},"\/wpcom\/v2\/post-types":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/post-types"}]}},"\/wpcom\/v2\/top-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"period":{"description":"Zeitrahmen f\u00fcr Statistiken.","type":["string","integer"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/top-posts"}]}},"\/wpcom\/v2\/transients\/(?P<name>\\w{1,172})":{"namespace":"wpcom\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"name":{"description":"Name des zu l\u00f6schenden Transients.","type":"string","required":true}}}]},"\/wpcom\/v3":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v3"}]}},"\/wpcom\/v3\/blogging-prompts":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"after":{"description":"Schreibanregungen nach einem bestimmten Datum anzeigen.","type":"string","required":false},"before":{"description":"Schreibanregungen vor einem bestimmten Datum anzeigen.","type":"string","required":false},"force_year":{"description":"Erzwinge, dass die zur\u00fcckgegebenen Themenvorschl\u00e4ge f\u00fcr ein bestimmtes Jahr sind. Gibt nur einen Themenvorschlag f\u00fcr einen Tag zur\u00fcck.","type":"integer","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v3\/blogging-prompts"}]}},"\/wpcom\/v3\/blogging-prompts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr die Schreibanregung.","type":"integer","required":false}}}]},"\/wpcom\/v3\/jitm":{"namespace":"wpcom\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"message_path":{"type":"string","description":"Der Nachrichtenpfad, f\u00fcr den JITMs abgerufen werden","required":true},"query":{"type":"string","description":"Zus\u00e4tzliche Abfrageparameter","required":false},"full_jp_logo_exists":{"type":"boolean","description":"Ob das vollst\u00e4ndige Jetpack-Logo existiert","required":false}}},{"methods":["POST"],"args":{"id":{"type":"string","description":"Die ID der zu verwerfenden JITM","required":true},"feature_class":{"type":"string","description":"Die Funktionsklasse der JITM","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v3\/jitm"}]}},"\/wpcom\/v2\/gutenberg\/available-extensions":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/gutenberg\/available-extensions"}]}},"\/wpcom\/v2\/hello":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/hello"}]}},"\/wpcom\/v2\/memberships\/status\/?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"source":{"type":"string","required":false},"is_editable":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/memberships\/status\/?"}]}},"\/wpcom\/v2\/memberships\/product\/?":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"title":{"type":"string","required":true},"price":{"type":"number","required":true},"currency":{"type":"string","required":true},"interval":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"buyer_can_change_amount":{"type":"boolean","required":false},"tier":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/memberships\/product\/?"}]}},"\/wpcom\/v2\/memberships\/products\/?":{"namespace":"wpcom\/v2","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"currency":{"type":"string","required":true},"type":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false}}},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/memberships\/products\/?"}]}},"\/wpcom\/v2\/memberships\/product\/(?P<product_id>[0-9]+)\/?":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"title":{"type":"string","required":true},"price":{"type":"number","required":true},"currency":{"type":"string","required":true},"interval":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"buyer_can_change_amount":{"type":"boolean","required":false},"tier":{"type":"integer","required":false},"description":{"type":"string","required":false}}},{"methods":["DELETE"],"args":{"cancel_subscriptions":{"type":"boolean","required":false}}}]},"\/wpcom\/v2\/publicize\/connection-test-results":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/publicize\/connection-test-results"}]}},"\/wpcom\/v2\/service-api-keys\/(?P<service>[a-z\\-_]+)":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"service_api_key":{"type":"string","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wpcom\/v2\/subscribers\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/count"}]}},"\/wpcom\/v2\/subscribers\/counts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wpcom\/v2\/subscribers\/counts"}]}},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/site":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/site"}]}},"\/jetpack\/v4\/connection\/test":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/test"}]}},"\/jetpack\/v4\/connection\/test-wpcom":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/test-wpcom"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"Mit \u201efalse\u201c wird die Verbindung zur Website getrennt.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Gibt zum Zweck der Nachverfolgung\/Segmentierung an, wo die Registrierungsaktion ausgel\u00f6st wurde","type":"string","required":false},"redirect_uri":{"description":"URI der Administratorseite, auf die der Benutzer nach dem Verbinden weitergeleitet werden soll","type":"string","required":false},"plugin_slug":{"description":"Gibt an, von welchem Plugin die Anfrage kommt","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI der Administratorseite, auf die der Benutzer nach dem Verbinden weitergeleitet werden soll","type":"string","required":false},"from":{"description":"Tracking-\/Segmentierungskennung f\u00fcr diese Autorisierungs-URL-Anfrage","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"Neues Benutzer-Token","type":"string","required":true},"is_connection_owner":{"description":"Ist Verbindungseigent\u00fcmer","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"Neuer Eigent\u00fcmer","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/jetpack\/v4\/connection\/owner\/protect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/owner\/protect"}]}},"\/jetpack\/v4\/connection\/owner\/release":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/jetpack\/v4\/connection\/owner\/release"}]}},"\/mcp":{"namespace":"mcp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mcp","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/mcp"}]}},"\/mcp\/mcp-oauth-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/mcp\/mcp-oauth-server"}]}},"\/mcp\/mcp-adapter-default-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/mcp\/mcp-adapter-default-server"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Den Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean","required":false},"ignore_sticky":{"description":"Ob oben gehaltene Beitr\u00e4ge ignoriert werden sollen oder nicht.","type":"boolean","default":true,"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Ob der Beitrag jemals ver\u00f6ffentlicht wurde.","default":false}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Ob der Beitrag jemals ver\u00f6ffentlicht wurde.","default":false}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Ob der Beitrag jemals ver\u00f6ffentlicht wurde.","default":false}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"iawp_total_views":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps oder bestimmter Medientypen begrenzen.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs oder bestimmter MIME-Typen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Ob Bilduntergr\u00f6\u00dfen erzeugt werden sollen.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Ob Bildformate konvertiert werden sollen.","required":false},"url":{"type":"string","format":"uri","description":"Die URL eines externen Bildes, das in die Mediathek \u00fcbertragen werden soll, anstatt eine Datei hochzuladen.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"yasr_visitor_votes":{"description":"Yasr Visitor Votes Data","type":"object","properties":{"sum_votes":{"type":"integer"},"number_of_votes":{"type":"integer"},"stars_attributes":{"read_only":{"type":"boolean"},"span_bottom":{"type":"boolean"}}},"required":false},"yasr_all_itemtypes":{"description":"Yasr Supported Item Types","type":"object","required":false},"yasr_all_itemtypes_addition_info":{"description":"Yasr Item Types Additional Info","type":"object","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL zur bearbeiteten Bilddatei.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array an Bildbearbeitungen.","type":"array","minItems":1,"items":{"description":"Bildbearbeitung.","type":"object","required":["type","args"],"oneOf":[{"title":"Spiegeln","properties":{"type":{"description":"Die Art der Spiegelung.","type":"string","enum":["flip"]},"args":{"description":"Die Spiegelungs-Argumente.","type":"object","required":["flip"],"properties":{"flip":{"description":"Die Richtung der Spiegelung.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Ob in horizontaler Richtung gespiegelt werden soll.","type":"boolean"},"vertical":{"description":"Ob in vertikaler Richtung gespiegelt werden soll.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotations-Typ.","type":"string","enum":["rotate"]},"args":{"description":"Rotations-Argumente.","type":"object","required":["angle"],"properties":{"angle":{"description":"Winkel in Grad f\u00fcr die Rotation im Uhrzeigersinn.","type":"number"}}}}},{"title":"Zuschneiden","properties":{"type":{"description":"Typ des Zuschnitts.","type":"string","enum":["crop"]},"args":{"description":"Zuschnitt-Argumente.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontale Position von links, an der der Zuschnitt beginnen soll, in Prozent der Bildbreite.","type":"number"},"top":{"description":"Vertikale Position von oben, an der der Zuschnitt beginnen soll, in Prozent der Bildh\u00f6he.","type":"number"},"width":{"description":"Die Breite des Zuschnitts in Prozent der Bildbreite.","type":"number"},"height":{"description":"Die H\u00f6he des Zuschnitts in Prozent der Bildh\u00f6he.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Der Bereich in Grad, um den das Bild im Uhrzeigersinn gedreht werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Die x-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Die y-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Die Breite des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Die H\u00f6he des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"image_size":{"description":"Die Bildgr\u00f6\u00dfe. Sie kann ein einzelner Gr\u00f6\u00dfenname oder ein Array mit Gr\u00f6\u00dfennamen sein, um dieselbe Datei unter mehreren Gr\u00f6\u00dfen zu registrieren.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Ob Bildformate konvertiert werden sollen.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"sub_sizes":{"description":"Ein Array mit Metadaten von Untergr\u00f6\u00dfen, extrahiert aus \u00dcbertragungsantworten.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Gr\u00f6\u00dfenname oder ein Array aus Gr\u00f6\u00dfennamen, wenn eine einzelne Datei unter mehreren Gr\u00f6\u00dfen mit identischen Ma\u00dfen registriert ist.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision der globalen Stile.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung der Revision f\u00fcr globale Stile.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Die ID der globalen Stile-Konfiguration.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globale Stile.","type":["object"],"required":false},"settings":{"description":"Globale Einstellungen.","type":["object"],"required":false},"title":{"description":"Der Titel der globalen Stilvariante.","type":["object","string"],"properties":{"raw":{"description":"Der Titel der globalen Stilvariante, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Schriftschnitt-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/feedback":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"source":{"description":"Schr\u00e4nke die Ergebnisse auf Feedback ein, das von einer bestimmten Quell-Beitrags-ID \u00fcbermittelt wurde.","type":"integer","required":false},"is_unread":{"description":"Ergebnissatz auf gelesene oder ungelesene Feedback-Elemente begrenzen.","type":"boolean","required":false},"is_test":{"description":"Beschr\u00e4nkt Ergebnismenge auf Testantworten (aus der Formularvorschau) oder schlie\u00dft sie aus.","type":"boolean","required":false},"invalid_ids":{"description":"Liste der Element-IDs, die unabh\u00e4ngig von Filtern in die Ergebnisse aufgenommen werden sollen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"fields_format":{"description":"Format f\u00fcr die Felddaten in der Antwort.","type":"string","enum":["label-value","collection"],"default":"label-value","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback"}]}},"\/wp\/v2\/feedback\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/feedback\/filters":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/filters"}]}},"\/wp\/v2\/feedback\/integrations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"version":{"type":"integer","default":1,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/integrations"}]}},"\/wp\/v2\/feedback\/integrations-metadata":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/integrations-metadata"}]}},"\/wp\/v2\/feedback\/integrations\/(?P<slug>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","required":true}}},{"methods":["DELETE"],"args":{"slug":{"type":"string","required":true}}}]},"\/wp\/v2\/feedback\/bulk_actions":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","enum":["mark_as_spam","mark_as_not_spam"],"required":true},"post_ids":{"type":"array","items":{"type":"integer"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/bulk_actions"}]}},"\/wp\/v2\/feedback\/trash":{"namespace":"wp\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"status":{"type":"string","enum":["trash","spam"],"default":"trash","required":false},"post_ids":{"type":"array","items":{"type":"integer"},"required":false},"search":{"type":"string","required":false},"parent":{"type":"integer","required":false},"source":{"type":"integer","required":false},"before":{"type":"string","format":"date-time","required":false},"after":{"type":"string","format":"date-time","required":false},"is_unread":{"type":"boolean","required":false},"is_test":{"type":"boolean","required":false},"limit":{"description":"L\u00f6sche h\u00f6chstens so viele Antworten und melde dann, ob noch weitere \u00fcbrig sind.","type":"integer","minimum":1,"maximum":5000,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/trash"}]}},"\/wp\/v2\/feedback\/config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/config"}]}},"\/wp\/v2\/feedback\/(?P<id>\\d+)\/read":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"type":"integer","required":true},"is_unread":{"type":"boolean","required":true}}}]},"\/wp\/v2\/feedback\/dismiss-classic-forms-notice":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/dismiss-classic-forms-notice"}]}},"\/wp\/v2\/feedback\/counts":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"description":"Limit results to those matching a string.","type":"string","required":false},"parent":{"description":"Limit results to those of a specific parent ID.","type":"integer","required":false},"before":{"description":"Limit results to feedback published before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"after":{"description":"Limit results to feedback published after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"is_unread":{"description":"Limit results to read or unread feedback items.","type":"boolean","required":false},"is_test":{"description":"Limit results to test responses or exclude them.","type":"boolean","required":false},"source":{"description":"Limit results to feedback submitted from a specific source post ID.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/feedback\/counts"}]}},"\/wp\/v2\/jetpack-forms":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false},"jetpack_forms_context":{"description":"Anfragekontext f\u00fcr Jetpack Forms. Verwende \u201eDashboard\u201c, um nur Dashboard-Felder einzuschlie\u00dfen.","type":"string","default":"","enum":["","dashboard"],"required":false},"has_responses":{"description":"Formulare danach filtern, ob sie Antworten haben. \u201eWahr\u201c gibt nur Formulare mit Antworten zur\u00fcck, \u201eFalsch\u201c gibt nur Formulare ohne Antworten zur\u00fcck.","type":"string","enum":["","true","false"],"default":"","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"_jetpack_forms_source_post_id":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/jetpack-forms"}]}},"\/wp\/v2\/jetpack-forms\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"_jetpack_forms_source_post_id":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<id>[\\d]+)\/preview-url":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Formular.","type":"integer","required":true}}}]},"\/wp\/v2\/jetpack-forms\/status-counts":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/jetpack-forms\/status-counts"}]}},"\/wp\/v2\/jetpack-forms\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"_jetpack_forms_source_post_id":{"type":"integer","title":"","description":"","default":0},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/jetpack-forms\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/activity-log-events":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/activity-log-events"}]}},"\/wp\/v2\/activity-log-events\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/activity-log-events\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/activity-log-events\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/jp_pay_order":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/jp_pay_order"}]}},"\/wp\/v2\/jp_pay_order\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/jp_pay_product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"spay_price":{"type":"number","title":"","description":"Einfaches Bezahlen; Preis.","default":0},"spay_currency":{"type":"string","title":"","description":"Einfaches Bezahlen; W\u00e4hrungscode.","default":""},"spay_cta":{"type":"string","title":"","description":"Einfaches Bezahlen; Text mit \u201eKaufen\u201c oder anderer Aufforderung","default":""},"spay_multiple":{"type":"boolean","title":"","description":"Einfaches Bezahlen; mehrere Elemente zulassen","default":false},"spay_email":{"type":"string","title":"","description":"Einfaches Bezahlen-Button; PayPal-E-Mail-Adresse.","default":""},"spay_status":{"type":"string","title":"","description":"Einfaches Bezahlen; Status.","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/jp_pay_product"}]}},"\/wp\/v2\/jp_pay_product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"spay_price":{"type":"number","title":"","description":"Einfaches Bezahlen; Preis.","default":0},"spay_currency":{"type":"string","title":"","description":"Einfaches Bezahlen; W\u00e4hrungscode.","default":""},"spay_cta":{"type":"string","title":"","description":"Einfaches Bezahlen; Text mit \u201eKaufen\u201c oder anderer Aufforderung","default":""},"spay_multiple":{"type":"boolean","title":"","description":"Einfaches Bezahlen; mehrere Elemente zulassen","default":false},"spay_email":{"type":"string","title":"","description":"Einfaches Bezahlen-Button; PayPal-E-Mail-Adresse.","default":""},"spay_status":{"type":"string","title":"","description":"Einfaches Bezahlen; Status.","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/jp_pay_product\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"yasr_overall_rating":{"type":"number","title":"","description":"","default":0},"yasr_post_is_review":{"type":"string","title":"","description":"","default":""},"yasr_auto_insert_disabled":{"type":"string","title":"","description":"","default":""},"yasr_review_type":{"type":"string","title":"","description":"","default":""},"spay_price":{"type":"number","title":"","description":"Einfaches Bezahlen; Preis.","default":0},"spay_currency":{"type":"string","title":"","description":"Einfaches Bezahlen; W\u00e4hrungscode.","default":""},"spay_cta":{"type":"string","title":"","description":"Einfaches Bezahlen; Text mit \u201eKaufen\u201c oder anderer Aufforderung","default":""},"spay_multiple":{"type":"boolean","title":"","description":"Einfaches Bezahlen; mehrere Elemente zulassen","default":false},"spay_email":{"type":"string","title":"","description":"Einfaches Bezahlen-Button; PayPal-E-Mail-Adresse.","default":""},"spay_status":{"type":"string","title":"","description":"Einfaches Bezahlen; Status.","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/jp_pay_product\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/rm_content_editor":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","spam","jp-temp-feedback","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/rm_content_editor"}]}},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","spam"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"default":"asc","description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sammlung nach Benutzerattribut sortieren.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder eine einzelne Rolle.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die mindestens eine bestimmte angegebene Berechtigung haben. Akzeptiert werden eine CSV-Liste oder eine einzelne Berechtigung.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die Beitr\u00e4ge ver\u00f6ffentlicht haben.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","feedback":"feedback","jetpack_form":"jetpack_form","jp_act_log_event":"jp_act_log_event","jp_pay_order":"jp_pay_order","jp_pay_product":"jp_pay_product","rm_content_editor":"rm_content_editor"}},"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":true},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":true},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":true},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Kommentare ausschlie\u00dft, die einer bestimmten Benutzer-ID zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","format":"email","type":"string","required":false},"before":{"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Kommentarattribut sortieren.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Sicherstellen, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"type":{"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"default":"post","description":"Ergebnisse auf Elemente eines Objekt-Typs beschr\u00e4nken.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ergebnisse auf einen oder mehrere Objekt-Subtypen einschr\u00e4nken.","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Eindeutiger registrierter Name f\u00fcr den Block.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribute f\u00fcr den Block.","type":"object","default":[],"required":false},"post_id":{"description":"Die ID des Beitragskontextes.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blockname.","type":"string","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"jetpack_ai_writing_assistant_enabled":{"title":"","description":"Ob der Jetpack\u00a0AI-Schreibassistent aktiviert ist.","type":"boolean","required":false},"jetpack_ai_image_editor_enabled":{"title":"","description":"Ob der Jetpack\u00a0AI-Bildeditor aktiviert ist.","type":"boolean","required":false},"jetpack_ai_feature_clip_enabled":{"title":"","description":"Ob die Generierung von Jetpack\u00a0AI-Videoclips aktiviert ist.","type":"boolean","required":false},"jetpack_ai_seo_enabled":{"title":"","description":"Ob die Jetpack AI SEO-Funktionen aktiviert sind.","type":"boolean","required":false},"jetpack_premium_analytics_enabled":{"title":"","description":"Ob das Premium Analytics-Dashboard f\u00fcr diese Website aktiviert ist.","type":"boolean","required":false},"title":{"title":"Titel","description":"Website-Titel.","type":"string","required":false},"description":{"title":"Untertitel","description":"Website-Untertitel.","type":"string","required":false},"url":{"title":"","description":"Website-URL.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Diese Adresse wird f\u00fcr administrative Zwecke verwendet, wie Benachrichtigungen \u00fcber neue Benutzer.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Eine Stadt in deiner Zeitzone.","type":"string","required":false},"date_format":{"title":"","description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string","required":false},"time_format":{"title":"","description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string","required":false},"start_of_week":{"title":"","description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer","required":false},"language":{"title":"","description":"Der WordPress-Lokalisierungscode.","type":"string","required":false},"use_smilies":{"title":"","description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean","required":false},"default_category":{"title":"","description":"Standard-Beitragskategorie.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standard-Beitragsformat.","type":"string","required":false},"posts_per_page":{"title":"Maximale Beitragsanzahl pro Seite","description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer","required":false},"show_on_front":{"title":"Vorne anzeigen","description":"Was auf der Homepage angezeigt werden soll","type":"string","required":false},"page_on_front":{"title":"Titelseite","description":"Die ID der Seite, die auf der Homepage angezeigt werden soll","type":"integer","required":false},"page_for_posts":{"title":"","description":"Die ID der Seite, auf der die neuesten Beitr\u00e4ge angezeigt werden sollen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Kommentare bei neuen Beitr\u00e4gen erlauben","description":"Erlaubt Personen, neue Beitr\u00e4ge zu kommentieren.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Website-Logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Website-Icon.","type":"integer","required":false},"jetpack_search_ai_behavior_instructions":{"title":"","description":"","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ergebnissatz auf Themes begrenzen, die einem oder mehreren Status zugewiesen sind.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Das Stylesheet des Themes. Dieses identifiziert das Theme eindeutig.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Titelform im WordPress.org-Plugin-Verzeichnis.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID einer registrierten Seitenleiste","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Verschachtelte Widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false},"form_data":{"description":"Serialisierte Widget-Formulardaten zur Kodierung in Instanz-Einstellungen.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Die Seitenleiste, f\u00fcr die Widgets zur\u00fcckgegeben werden sollen.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":true},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":false},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Ob das Entfernen des Widgets erzwungen werden soll oder ob es in die inaktive Seitenleiste verschoben werden soll.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ergebnissatz auf Bl\u00f6cke beschr\u00e4nken, die mit dem Suchbegriff \u00fcbereinstimmen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","minLength":1,"required":false},"category":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Kategorie-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Stichwort-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Vorlage (Titelform) \u00fcbereinstimmen.","type":"array","required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Zu verarbeitende URL.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Eine alphanumerische Kennung f\u00fcr die Men\u00fcposition.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Eine eindeutige Kennung f\u00fcr die F\u00e4higkeitskategorie.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Eingabeparameter f\u00fcr die Ausf\u00fchrung der F\u00e4higkeit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Die Ergebnisse auf F\u00e4higkeiten einer bestimmten F\u00e4higkeitskategorie begrenzen.","type":"string","required":false},"namespace":{"description":"Ergebnisse auf F\u00e4higkeiten in einem bestimmten Namensraum beschr\u00e4nken.","type":"string","required":false},"meta":{"description":"Ergebnisse auf F\u00e4higkeiten beschr\u00e4nken, die allen angegebenen Meta-Feldern entsprechen.","type":"object","properties":{"annotations":{"description":"Ergebnisse auf F\u00e4higkeiten beschr\u00e4nken, die den angegebenen verhaltensbezogenen Anmerkungen entsprechen.","type":"object","properties":{"readonly":{"description":"Ob die F\u00e4higkeit ihre Umgebung nicht ver\u00e4ndert.","type":["boolean","null"]},"destructive":{"description":"Ob die F\u00e4higkeit destruktive \u00c4nderungen an ihrer Umgebung durchf\u00fchren kann.","type":["boolean","null"]},"idempotent":{"description":"Ob wiederholte Aufrufe mit denselben Argumenten keine zus\u00e4tzliche Auswirkung haben.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"collection":{"description":"Ergebnisse auf Icons beschr\u00e4nken, die zur angegebenen Sammlungs-Titelform geh\u00f6ren.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Ergebnisse auf Icons beschr\u00e4nken, die zur angegebenen Sammlungs-Titelform geh\u00f6ren.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Der Icon-Name.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform der Icon-Sammlung.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Entit\u00e4tsart.","type":"string","required":true},"name":{"description":"Entit\u00e4tsname.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.lte-anbieter.info\/lte-hardware\/all\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":0,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
